Way around unsupported 915p chipset with protools?
So i worked out what has to be the problem with my pro tools buffering out every 20secs when recording, my intel chipset 915p is one not supported by 7.1 - There has to be away or patch or something around this?
... I would very much love to change systems however i have spent alll of my money getting a good enough pc, mbox, mic etc. and really am just fiending to get on the mic and record and get to knowing this program inside out. Here's a little info i copied over: once again thank you very much for your time! Chipset Detected Chipset: Intel(R) 915 Express Chipset family Chipset Components Memory Controller: 82915G/P I/O Controller: Intel(R) 82801FR I/O controller hub (ICH6R) hmm - is it worth downloading these for the chip : http://support.intel.com/support/chi.../CS-011594.htm ?? .. I have a Pentium 4 : it suggests this: Suggested workaround: For heavily loaded audio solutions, the best alternative is to utilize systems based on chipsets that utilize the B-2 or C-0 step of the ICH6 component, which has been better optimized for heavy audio traffic. Also, although Intel has not validated a high speed USB hub as a solution to this issue, we are aware of certain 3rd party system manufacturers that are using an external high speed USB hub to mitigate this issue on platforms with the B-1 step of the ICH6 component." Chipset Requirements with Intel Pentium 4 processors & Digidesign/M-Audio USB Devices The following chipsets have been approved with desktop computers with Intel P4 processors: * Intel 955X* * Intel 945G/945P* * Intel 925XE * Intel 915PL * Intel 915GL/915GV * Intel 875P * Intel 865PE * Intel 850/850E * Intel 845/845E/845PE Not sure what most of this means....once again anyone have any solutions or care to school me on this? Regards, |
Re: Way around unsupported 915p chipset with protools? *DELETED*
Post deleted by casperfun
You are not going to get any different answers than you did
the first time you asked and the second time you asked The only known workaround is the one that JMS40 mentioned the first time you asked: try using a powered USB hub. THe workaround is not a guarantee, though, and you would be better served getting a computer that is compatible.
Sorry mang, i couldn't find my other threads and figured they had been deleted or something, a simple mistake
Shall try working with an external USB hub...how much will changing the chipset run me? regards, |
http://cgi.ebay.com.au/BRAND-NEW-4-p...QQcmdZViewItem
is this what you mean by externam usb hub, might give it a shot if its that cheap:) regards, |
That is not a "POWERED" usb hub.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
It says self powered?
What about this one : http://cgi.ebay.com.au/POWERED-4-POR...QQcmdZViewItem Thanks! |
Hello guys
I'm reading this post about chipset compatibility. One client of mine has a stability problem with what seems to be a compatible chipset. He's experiencing reboots when PT is in use. I'm suspecting some bad install or configuration of the OS (XP pro SP2).The motherboard is an Asus P5LD2, which has socket 775 and Intel 945P chipset. Any infos of the compatibility of this chipset with PT 6.x versions? Is it only suitable for PT7 use? Thanx L.G. |
Powered USB hub = wall wart power supply.
You cannot change the Chipset.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
XP Chipset workaround 915P (USB Hub) | P Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-03-2007 02:22 AM |
PT LE with Intel 915P chipset. Will it ever work? | Xfade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-14-2006 12:46 AM |
Hope for owners of the incompatable 915p chipset | jimmyjamesMT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-06-2005 12:15 AM |
915P chipset versus the 915PM chipset | valleyarts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-28-2005 02:22 AM |
Intel® 915P Express chipset and the Intel® Pentium | darkglass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 03-23-2005 06:05 PM |
