Old 03-17-2020, 03:47 AM
marcelkavka marcelkavka is offline
Default copy - paste output window
does anyone have an idea how to copy and paste all settings (pan position, level) in the output window like in any plug in window?
Old 03-18-2020, 06:26 AM
priorytools priorytools is offline
Default Re: copy - paste output window
Originally Posted by marcelkavka View Post
Try;
Make a mix group those channels, selecting volume & pan in the attributes tab.
Now, with groups active tweak one of those channels & all members should follow.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 03-19-2020, 03:59 AM
Thanks.
I know. That's not what I mean. There are several ways to copy automation from one clip to another, even just pan automation.
But first you have to write automation to one track and then copy-paste it.
Looks like the feature I am looking for, is missing.
Old 03-19-2020, 06:25 AM
Thanks.
My groups suggestion doesn’t require automation.
Old 03-19-2020, 07:25 AM
its2loud its2loud is offline
Duplicate the track without playlists. Right click menu -> Duplicate.
This is assuming you want to copy the entire track for the entire session length.
Old 03-24-2020, 06:09 AM
It's about all parameters in the output window (l-r position, divergence, f-r position, center%...). Plug-ins have the "copy settings" and "paste settings" command. That's what I'm looking for.
Old 03-24-2020, 07:21 AM
Doesn’t exist.
Log it as a feature request.
Meanwhile, use the grouping work around I suggested.
Old 03-24-2020, 07:42 AM
Your post suggest that you want to copy pan automation.
This can be done in under the Copy Special—> Pan Automation menu option
Copy... Paste... Paste... Paste...? accession 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-18-2022 04:18 PM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
'Copy and Paste' it took me years to save Post - Surround - Video 2 12-06-2010 05:34 AM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
can't copy/paste in new folder window in 7.4 jking7771 Pro Tools TDM Systems (Mac) 1 06-05-2008 10:22 AM
