Old 04-16-2008, 11:36 AM
kelli kelli is offline
Default exporting midi files using strike
is there a way to export the drum samples from stike on to just one track? I'm mainly using this for songwriting now and would like the convenience of arranging verse, chorus, intro's etc. on just one track instead of many. Also, I'e noticed that I really have to be careful about how i record the bit that I want to export for example sometimes the last cymbal hit of the measure gets cut off so there is a gap when I try to use it as a loop. Is there an automatic way of exporting a loop without manually recording it with the buttons? I like using separate repeated loops because it is then easy to keep track of how many times progressions are played and editing the song arrangement is easy.
kjo
Old 04-16-2008, 06:36 PM
Mount Royal Mount Royal is offline
Default Re: exporting midi files using strike
To my knowledge, no there is no way. An obvious Strike weak point is, in my mind, the inability to export a style's midi data in a usable way. Let's hope this will be remedied as the plug is still pretty new.
John-
Pro Tools 2018.4
HDX, 192 and Lucid I/O
5,1 MacPro 12 Core; OSX 10.12.6
Strike - Newbie Question - Exporting Midi modonnell43 Virtual Instruments 3 09-13-2012 04:49 AM
Strike and exporting to separate midi tracks cboyer1951 Virtual Instruments 3 10-24-2010 03:26 PM
Strike trouble (exporting MIDI performance) please HELP! abitpart Virtual Instruments 2 08-21-2008 12:54 AM
Exporting MIDI files JamesJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-27-2007 11:30 PM
Problems Exporting Midi Files smmdrum MIDI 1 10-29-2002 06:21 PM
