Old 02-25-2008, 03:00 PM
gleiter gleiter is offline
Default Help with transferring ADAT tapes to PT - clock issues?
Hi. I'm trying to transfer old ADAT tapes (Alesis 16-bit era) to my PTLE 7.4 system. While trying to do so, I get a lot of clicks - the kind I associate with clock issues (several per second, pretty randomly spaced). I've switched the PT clock from 'internal' to 'optical', tried setting the PT sessions to both 16 and 24-bit as well as 44.1 kHz and 48 kHz, tried similar combos on the ADAT as well. Still getting the clicks.
Am I missing anything? Thanks.
GL
Old 02-25-2008, 03:17 PM
cyberstudio cyberstudio is offline
Default Re: Help with transferring ADAT tapes to PT - clock issues?
All you need is to double check everything.
I remember working with PTLE 7.1 on Mac there was somehow no way of syncing PT to incoming lightpipe, while 6.4 did is perfectly both directions. I had to clock ADAT XT from PT - setting PT internal sync and ADAT to EXT (DIG - I don't remember).
Connecting it both ways via lightpipe makes research easier. If your tapes are 48k - better set your sample rate in PT to the same sample rate. Make sure ADAT tapes and heads are clean - sometimes dirty head can make similar artefacts as clock issues.
Clock loop can cause 40700Hz sample rate but this is another story.
c y b e r s t u d i o
P O L A N D
002R ADAT clock issues... cwhite771 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-19-2007 03:38 PM
one adat-- two tapes( track alignment in 001) ??? tdyoder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-08-2004 05:23 AM
2 tapes, 1 Adat keny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-19-2002 12:22 AM
Good source for ADAT tapes Gingley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-01-2002 02:15 PM
ADI-8 PRO - transfer to Digi001 over ADAT and Clock issues Sofine General Discussion 4 06-24-2001 08:02 PM
