Old 12-30-2019, 12:14 PM
mrllnfn mrllnfn is offline
Default Cannot Embed Eleven Setting PT12
I use Slate MTi2 (2 screens). I have a Mac Mini (2.6 Ghz Core i5 *GB 1600 MHz DDR3) running Sierra (10.12.6).
I upgraded to PT 12 (2019.12.0) and I cannot get my Eleven Rack to embed the settings. In the Input I/O setup the place where you would normally select Embed Eleven Settings From is blank with no way to enter anything.
I also cannot use the Clips right click method because the Load Settings selection does not appear.
Any help would be greatly appreciated. Thanks.
File Type: jpg Screen Shot 2019-12-30 at 12.11.32 PM.jpg (39.5 KB, 0 views)
Old 12-30-2019, 08:56 PM
Pingafuego Pingafuego is offline
Default Re: Cannot Embed Eleven Setting PT12
Did you update the eleven rack driver? I had to revert it to previous version to re enable the embedding
Old 12-31-2019, 03:02 PM
Hi, just checked my DAW (Pro Tools 2019.12.0), Mac OS 10.13.16, and the embedding appears to be working, and I am able to select settings, as all inputs form Eleven Rack appear as options for rig embedding.
Setting up a Low Latency Output pair in PT12 johnnybregar Pro Tools HDX & HD Native Systems (Mac) 2 11-29-2016 08:29 PM
Eleven + Eleven MkII + PT12.5.2 on Windows 7 seanbil Windows 2 08-01-2016 01:45 PM
2011 MBP - PT12, crackling/pops at 64 buffer setting SixChurchStreet macOS 3 02-14-2016 05:11 AM
eleven rack embed settings after recording? YYR123 Eleven Rack 6 08-20-2013 10:22 AM
