Old 09-09-2002, 04:44 AM
gringito gringito is offline
Default "audio processing is conflicting with other CPU tasks..."
...If this occurs often, try reducing the "H/W buffer size in the hardware setup panel"...
and When I reduced the buffer size, the problem is changing in :"...increase the buffer size" !!
I've this problem since I've re-install pro-tools after the "cleaning" of my hard drive [img]images/icons/confused.gif[/img]
In fact I've no problem to record, It's inly when I played the files...
please help me,
thanks.
GB
Old 09-09-2002, 05:49 AM
Bastiaan Bastiaan is offline
Default Re: "audio processing is conflicting with other CPU tasks..."
enable dma on your harddrives....
enable usb under winxp...(strange but true....)
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 09-09-2002, 07:33 AM
thank you !!!!
Old 09-09-2002, 08:52 AM
Tell us, waht did the trick?
What's that?
Bastiaan
audio processing conflicting with other CPU tasks elvidge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-01-2006 11:03 PM
Audio processing conflicting with cpu tasks...? Beyond The Pale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 05-11-2006 04:31 AM
Audio Processing is Conflicting w/ Other CPU Tasks chillax69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-18-2006 07:30 AM
Audio Processing conflicting with CPU Tasks Sebastian C. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-02-2004 10:52 AM
Audio processing is conflicting with other CPU tasks bersonique 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-24-2001 06:16 PM
