Old 06-08-2003, 04:12 PM
BlackOctopus BlackOctopus is offline
Default Audio won\'t play back!!!
I have the following set-up.
iMac G4 running OS9.2.2 / MBox LE 5.2...
everything runs fine until i just started a new session..suddenly my audio tracks don'y play back!!
Transport blue arrow is highlighted, but the selector / cursor doesn't move..audio doesn't play.
The main counter goes to: 00:00:00:00
it's the same on ALL my sessions now!...iTunes is playing back through the mbox fine....HELP! I need to finish two tracks today!!!! [img]images/icons/frown.gif[/img]
Old 06-08-2003, 05:03 PM
Carl Z Carl Z is offline
Default Re: Audio won\'t play back!!!
Do you have it set-up for external sync?
C
"I'm one of the few people I know who knows the few people I know" - CL
Old 06-08-2003, 05:37 PM
No..nothing has changed. I made an edit, went to play it back and the cursor just doesn't begin moving...i cannot figure it out...i have made NO changes to the set up.
Anyone??????
Old 06-10-2003, 06:32 PM
I trashed pt preferences and all was ok....but thanks for all the help. [img]images/icons/rolleyes.gif[/img]
Old 06-11-2003, 09:10 AM
J Gardner J Gardner is offline
This sounds a little like a problem I had and I'm a little embarrassed to admit it.
If you accidently hit the "Edit and Timeline" enable/disable button in the edit window no matter where you select in the timelime your playback will be from the last place that was selected. If you hit return that would be 00;00;00;00
It took me a while to see what had happened.
This might be your problem.
It's the button under the edit mode section next to the command a...z button
good luck
Jim
Trying to play back audio. lindenkillam macOS 1 08-07-2013 06:04 AM
Recorded audio will not play back? MattMacDonald 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 11-28-2007 05:20 PM
can not play back audio in pro tools? guitar2go 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-20-2007 09:58 AM
Can't play back audio.... BMerrell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-09-2006 12:54 AM
audio is visible; will not play back sidereal-studios Pro Tools TDM Systems (Mac) 7 12-28-2001 04:53 PM
