Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 05-29-2019, 12:27 PM
EddieJones's Avatar
Default Re: Downgrade PT Control iPad back to 18.3.0
https://imazing.com/ios-app-management
Old 05-29-2019, 01:45 PM
mrtomcat mrtomcat is offline
Thanks Eddie,
it gets halfway through the install and then says "Request was missing the Package Path"
is there anything else needed other than the .ipa file?
Mixing/Producing/Recording
PT Ultimate 2019.5
Wavelab Pro 9.5
UAD Satellite Octo Thunderbolt,
Apollo Twin Duo,
HDX Card running in Sonnet TB3 expansion box,
2x Avid I/O Analog 16/16,
4x Artist Mix, Avid Dock, PT Control,
Mac Mini 2018 32gig ram 1 TB SSD 6 Core running Mojave,
lots of outboard gear
Old 05-29-2019, 01:54 PM
EddieJones's Avatar
Originally Posted by mrtomcat View Post
Thanks Eddie,
Is this using imazing ?
Old 05-29-2019, 01:55 PM
yes
PT Ultimate 2019.5
Wavelab Pro 9.5
Apollo Twin Duo,
Old 05-29-2019, 02:24 PM
EddieJones's Avatar
We just tried it here...it used to work but its throwing errors now.
  #16
Old 05-29-2019, 03:45 PM
I wonder if there's an incompatibility with iOS 12.3.1
PT Ultimate 2019.5
Wavelab Pro 9.5
Apollo Twin Duo,
  #17
Old 05-31-2019, 07:37 AM
KeyplayerG's Avatar
KeyplayerG KeyplayerG is offline
Default Is there any way to get PT Control back to 18.3?
I didn't update to 19.5 because 18.3 was stable and working for me. The iPad did an automatic update to 19.5 and now won't work with my hardware.
I tried deleting 19.5 and re-downloading 18.3, and there is where I'm stuck. It's downloaded but it's not installing or even letting me save it on the tablet! I called Apple and they said I had to contact Avid.
Anybody here, know how to revert to an older version?
Last edited by DigiTechSupt; 06-01-2019 at 08:35 AM. Reason: Duplicate threads merged.
  #18
Old 06-01-2019, 06:52 AM
colliderman colliderman is offline
Not working here either.
First tried loading the app onto my iPad with iTunes 12.6. The app would disappear immediately after installing.
Also tried using iMazing. iMazing says the app is either not compatible with iOS10 or is corrupted.
Seems the app is corrupted because I'm running iOS 10.3.3 which is the version I was running PT Control 18.3 on before the inadvertent PT Control update.
@EddieJones any chance we could get a different .ipa build and try that? Possibly an earlier build?
Pro Tools 2018.12
OS X 10.12.6
Mac Mini (2012) Quad 2.3 GHz Intel Core i7
16 GB 1600 MHz DDR3 RAM
  #19
Old 06-01-2019, 07:18 AM
EddieJones's Avatar
Default Re: Is there any way to get PT Control back to 18.3?
It seems the way we used to do it has been blocked by Apple. Sorry
  #20
Old 06-01-2019, 04:21 PM
Doesn't make sense. I'm on iOS 10.3.3. That version should allow loading apps manually.
This is the error I'm getting - https://support.imazing.com/hc/en-us...ation-package-
Please, is it possible to supply a different build of the older version? It's worth a shot.
Pro Tools 2018.12
OS X 10.12.6
Downgrade back to 10.3.0? typhy Pro Tools 10 13 01-27-2016 06:06 PM
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION DESVED Pro Tools HDX & HD Native Systems (Mac) 2 05-21-2013 03:18 PM
iPad control jamesimm Pro Tools 9 5 11-03-2011 06:57 PM
PT9 Downgrade Back to PT8 LE maxspl Pro Tools 9 5 11-27-2010 09:30 PM
downgrade from LE 6.4 back to previous version croffutt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-25-2004 11:37 AM
