Old 04-30-2019, 09:30 AM
hannahjazzz hannahjazzz is offline
Default Master fader trouble
How do I bounce my master fader in pro tools to a new track that I am sending my mastering hardware to? In order to preserve my mastering I’ve done on the analog hardware I’m using to them bounce to mp3/ .wav/ CD.
Feel free to ask any questions.
Using PT LE 8
Old 04-30-2019, 12:16 PM
Top Jimmy's Avatar
Default Re: Master fader trouble
You seem to misunderstand what a master fader is. Master faders have nothing to do with routing audio. If you want to route your audio, you do that with inputs and outputs. Both audio tracks and aux tracks have inputs and outputs facilitating your routing. Master faders are simply a fader that allows you to scale the output of a bus or hardware output and it's a convenient place to put any final plugins.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 04-30-2019, 01:27 PM
Maybe I phrased it wrongly:
Basically my HHB CD recorder isn’t working and it’s being a nightmare.
Therefore I’m coming out of a valve machine via tc finalizer that was originally meant to go into the HHB to burn.
I want to set the valve machine outputs to the input of my 003 and then in pro tools record my master mix to burn to cd from my computer.
I’m wondering when assigning channels on my pro tools mix if I can bus them to the channel I have put my valve machine into and record the master mix?
Thanks
Old 04-30-2019, 02:46 PM
You are driving the mastering analog gear from the same Pro Tools session?
Create a new stereo audio track with its inputs whatever two inputs you have the mastering outputs connects to. Outputs on that track are either nothing or go to separated dedicated output pair so you can monitor them). Or assign the normal main outputs to some other output pair if you want to monitor the final result using your current monitors/headphone setup.
Nothing to do with master faders, just basic IO assignment. Read up on input and output IO settings, and maybe busses, in the reference guide if you need to.
Old 04-30-2019, 09:23 PM
JFreak's Avatar
JFreak JFreak is offline
Set up a hardware insert
Janne
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 05:36 AM
trouble routing to master fader radioinactive Pro Tools TDM Systems (Mac) 15 11-02-2010 11:35 AM
Master Fader 6.7 Master Fader issues Bogner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-19-2005 07:42 AM
Compress Master Fader before deciding on individual fader's plugins? Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-11-2002 12:04 AM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 07:41 AM
