Old 09-07-2017, 08:15 PM
lanstrad's Avatar
lanstrad lanstrad is offline
Default How do I get rid of Application Manager ????
I just rebuilt my entire system, reinstalled OSX 10.11.6 fresh, and for first time (on this system which used to work with PT 11) I have 12.8.1
However, there's this damn system hanger called Application Manager that keeps trying to load, waste my time, and be there when I don't want it. Been reading about complains on that for alsmost 2 years now... Please don'T tell me there is no way to get rid of this (at least set some preference *not to load' at every start up or log in ???)
Rob
____________________
Mac OS X El Capitan 10.11.6 (on CustomMac desktop) AND Mac OSX 10.12.x (on MacBook Pro) - Quad-core i7 2.86 ghz 16gb ram, nVidia GTX 650, RME Fireface 800 (SiiG fw card with TI chipset), MOTU midi express 128, Yamaha 02R digital mixer (connected to Fireface 800, ADAT IN/OUT). Pro Tools 11-12, Cubase Pro 8 / For Mac OS X Sierra, I use a Macbook Pro mid-2012, i7, 2.9 Ghz, 16gb with SSD 1TB.
Old 09-07-2017, 08:18 PM
Default Re: How do I get rid of Application MAnager ????
DUC has many many posts telling you to uninstall this and telling you how. I can't believe you even tried to find those instructions.
And it's easy...
Find AppManager Uninstaller and run it.
Same with Cloud Client Services Uninstaller (assuming you don't want that ******** on your system either).
Old 09-07-2017, 08:49 PM
lanstrad's Avatar
Thanks Darryl. Yes I agree I could have searched. Just have spent last few hours setting, resetting, installing stuff... And when I came to this, it was like the cherry on the cake... I like the ''********'' word by the way
Cheers,
Rob
Rob
Old 09-08-2017, 12:19 AM
zerodistraction zerodistraction is offline
I edit the launch agent PLIST and set the following:
<key>RunAtLoad</key>
<false/>
You can find that file in your root directory under Library > LaunchAgents.
It's called: com.avid.ApplicationManager.plist
Old 09-08-2017, 07:02 AM
lanstrad's Avatar
Is there an advantage to edit rather than remove? (Unless i eventually wish to change my mind - guess it always remain possible to update manually, unless there is an advantage i missed ?)
I've seen 3 ways so far. The 2 above, and Sweetwater give a 3rd one - simply flush 2 files/folders, but i'm slightly afraid on that one....???)
Thanks
Rob
Old 09-08-2017, 02:46 PM
_JJ_ _JJ_ is online now
Default Re: How do I get rid of Application Manager ????
I vote for removing...
In your Applications folder >> Avid_Uninstallers >>Application Manager >> AppManager Uninstaller.
While you're in the Avid_Uninstallers folder you may also want to uninstall "Cloud Client Services", unless you use them.
PT 12.7 Not Available in Application Manager rgast5150 Pro Tools 12 10 04-02-2017 09:23 PM
Application Manager v2.5.1 Now Available DigiTechSupt Technical Alerts 0 01-12-2016 07:02 PM
Application Manager hooksound Pro Tools 12 0 04-08-2015 10:00 AM
