Old 12-18-2013, 04:23 PM
Tigerfeet Tigerfeet is offline
Default HD Omni i/o
I'm deliberating between purchasing an HD8x8 or an Omni (I'm unclear around it's i/o flexibility). Essentially, I'm mixing TV shows and will need to simultaneously output 4 channels of analogue for monitoring and 4 channels of AES digital to the client digi/xdcam deck. Is the Omni up to this?
Regards,
Tigerfeet
SETUP:
iMac 27 Quad i7
16MB RAM
Pro Tools HD 11.3
Apogee Duet 2
Old 12-18-2013, 06:07 PM
RyanC RyanC is offline
Default Re: HD Omni i/o
I haven't done that exact thing, but looking at the hardware window yes you should be able to do that. IE stereo CR mon, stereo headphones send, 4ch AES to the deck? Or quad and quad? Either should work from what I'm looking at.
The CR monitoring quality of the omni should not be overlooked. My bigs are super high efficiency drivers and will expose upstream noise quite noticeably. I've tried a few different monitor controllers high end; and audiophile switched resistor networks etc fed from aurora and HDIO and the OMNI is very very good.
Old 12-18-2013, 09:17 PM
nst7 nst7 is offline
This can be done. Just keep in mind it's a max of 8 outs, regardless of analog or digital. So you could have 4 channels of analog out and 4 channels of AES/EBU out. Any output, analog or digital, that is not assigned to a monitor path, becomes just a straight line out.
Old 12-20-2013, 12:50 PM
Zeljko2 Zeljko2 is offline
I second that. It can be done easily on OMNI.
By the way I am selling one in Classifieds, need more channels...
Omni New 950.00 Barry Johns Pro Tools HDX & HD Native Systems (Mac) 18 03-17-2014 07:58 PM
Omni vs HD 8x8x8 io and Omni Pre's Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 13 03-27-2013 01:00 AM
OMNI vs HD I/O michael c macOS 4 04-06-2012 04:24 PM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
