Omni as headphone monitor
I have PT HD 10 and the OMNI. I do not have the native HD card at the moment. (I am arranging the purchase of one.) In the meantime, I would like to use the OMNI as a headphone monitor using the Optical IN (Toslink). The meters read that there is information coming in, but I don't hear anything in the headphones. Help! Thanks, Robert |
Re: Omni as headphone monitor
You would need to have it hooked up via an HD card in order to configure the mixer to receive the Digital input for this to work (and make sure the Headphone button is selected in that software mixer channel). Once you do that, it will stay that way until you change it, allowing you to use it as a standalone D/A converter.
But you must first configure it that way by having it hooked up to an HD system, either TDM, HD Native, or HDX. Perhaps you can do it in a friend's studio who has that. |
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
But he must first configure the Omni mixer to receive signal through the digital ins, and to do that it must be hooked up via an HD card. He's stated he doesn't have it hooked up that way. It's not set up that way out of the box.
And the Cue button would not apply in that situation. |
digital input selections can be made from the front panel. p41 of the Omni manual shows what can be configured outside of PT. and IIRC all inputs are monitored thru the mixer outta the box. it's when you wanna turn monitoring off for a particular input that is when you have to use the mixer from within PT software. at least that's the way i remember it when i set mine up...been awhile tho...
Help with Omni monitor and IO | Moviesound | Pro Tools HDX & HD Native Systems (Mac) | 1 | 02-28-2014 11:08 AM |
Omni can't pan left or right headphone out | willl3 | Pro Tools HDX & HD Native Systems (Win) | 5 | 06-26-2013 02:43 AM |
Creating an headphone mix on Omni ? | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 13 | 07-19-2012 07:38 AM |
Wattage of Headphone jack on OMNI ? | K Roche | Pro Tools HDX & HD Native Systems (Mac) | 1 | 04-30-2011 08:57 AM |
