HD Omni Mic Pre ?
I am New To HD Native / Omni I have done the Setup and I am Currentlly Using the system. I don't know why I can't hear the Mic's (Mic1/2) and there is no signle in the Track Level. The connection setup currentlly as following : Omni Back panel: Line 1 & 2 --> Motif XF Line 3 & 4 --> Tyros 3 TRS Out 1 & 2 --> Yamaha HS80M Monitors All the above is fine. Omni front Panel: when I am using the 2 inputs in front as INTST it's working fine. when I am try to use the 2 inputs or one of them as MIC it's doesn't work. If I click 48v button for any of the 2 inputs in front it show me small signal in PT @ the Track Vol Level but I can't hear any sound or see any signal in PT on the Track Vol level and I don't see any signal (in or Out) at the Omni Meters.! please I need adivce here since I am still new to HD world Thanks |
Re: HD Omni Mic Pre ?
Are you adjusting the rotary knob to increase your gain for those inputs?
yes
when I use normal mic (without 48v) it work fine (I can hear the sound).
but when I use my MIC (Rode NT2-A) with 48v button it doesn’t work |
Are you using a mic lead with the earth cut?
Can you please explain to me what is <using a mic lead with the earth cut?>
I am using a TRS cable and XLR adapter , I am not sure if this could be the issue or if it's related to your question... Is it Possible that the HD Omni Mic Pre isn't compatable with Rode NT2-A mic? |
The earth pin of the XLR cable transmits phantom power (48v) to power your condensor mic. It's possible that the adaptor is dropping the earth connector of your XLR and stopping the phantom from getting to your mic.
Grab your mic, and plug the XLR straight into the front of the omni (without the adapter), hit the 48v button, and see if you get any signal on the Omni meters. (make sure they are showing input) |
I will buy a XLR cable today and Try that Thanks |
Thank you for your advice |
HD Omni i/o | Tigerfeet | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-20-2013 12:50 PM |
Omni vs HD 8x8x8 io and Omni Pre's | Southsidemusic | Pro Tools HDX & HD Native Systems (Mac) | 13 | 03-27-2013 01:00 AM |
OMNI vs HD I/O | michael c | macOS | 4 | 04-06-2012 04:24 PM |
OMNI Fried? Calling Omni Members - Check High Samplerates | KingFish | Pro Tools TDM Systems (Mac) | 3 | 11-03-2011 09:19 PM |
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan | FRaNCo MuSiC | Pro Tools HDX & HD Native Systems (Win) | 0 | 09-25-2011 05:42 AM |
