Old 03-05-2008, 10:46 AM
AudioImpressions AudioImpressions is offline
Default GML 5-band EQ @ 192 on OS X...please help!!!
Hey all, a newbie to the forum over here...I need some help in a major way! For some reason (this is hopefully where y'all come in), my GML 5-band EQ (MDW) will not properly work in HD at 192 kHZ. The 3-band is fine, but when I try to instantiate the 5-band, it sounds like i put on a spectral domain processer with a "robot" preset (a la izotope's spectron)...does anyone know why this would be happening?! I need my GML!!!
I'm running OS X v. 10.4.11
Thanks, I appreciate any and all rapid responses.
Old 03-05-2008, 03:10 PM
Will Russell's Avatar
Will Russell Will Russell is offline
Default Re: GML 5-band EQ @ 192 on OS X...please help!!!
I don't want to sound like a jerk here, but for starters you are running a non-approved OS. We need more info to help you. Version of ProTools? Version of MDW EQ?
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.13.6, PT2018.12, HDX, D-Command
Retina 5k iMac OS 10.14.2, PT2018.12, MBox3
Retina MacBook Pro OS 10.14.2, PT2018.12
Old 03-05-2008, 04:00 PM
no worries, i appreciate any assistance you can give... PT HD version 7.2 cs3, MDW EQ version 2.0.2...waddaya think? (and p.s., it IS working at 96 kHz)
Old 03-05-2008, 04:10 PM
crizdee's Avatar
crizdee crizdee is offline
Do you have an accel card?
This is the TDM version right? not RTAS?
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 03-05-2008, 05:09 PM
yes, it's I've got 2 accel cards and i'm working with the TDM version
Old 03-06-2008, 07:06 AM
crizdee's Avatar
Just opened a 192k session and ran stereo TDM 5 band and mono 5 band and all was fine!
Have you manually removed from the plugins folder and re-installed the latest version?
Have you trashed the prefs for PT and re-booted?
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-06-2008, 01:40 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is online now
I did some testing and I have the same problem. I use the latest MDW 2.0.2r44 with PT HD 7.4cs4. All other plug-in's at 192 kHz are fine, only MDW 5 bands generates extreme digital noises
This is my setup:
PT HD 7 ACCEL system:
Mac G4 Dual 1.25 GHz (FW800) + 2 GB RAM + ATTO UL3D
OS X 10.4.11 + PT HD 7.4cs3 + Logic Pro 7.2.3
OS X 10.4.9 + PT HD 7.2cs3
PT HD 7 Accel (1 x HD Core PCI + 6 x HD Accel PCI) inside 7-slot 64 bit Digidesign PCI Exp. Chassis
192 I/O + AD expansion card + 192D I/O + SYNC I/O + MIDI I/O + ProControl + Avid Mojo
Apogee Big Ben + Apogee Rosetta 200 + Rosendahl Nanosyncs
Marc Schellekens
Delta Music - Pro Tools|HD Mix & Mastering Suite - Belgium
http://www.deltamusic.be
http://www.myspace.com/deltamusicbelgium
Marc Schellekens
Delta Music Belgium - Pro Tools | HDX Studio
System 1: Mac Pro (Mid 2012) 3.33 GHz 6-core - 32 GB RAM - OS X 10.13.6 - Magma EB7 - PT HDX3 - PT Ultimate 2018.12 - HD I/O 16x16 - 192 I/O - 192D I/O (x3) - SYNC HD I/O - Apogee Big Ben - Rosetta 200 - Slate RAVEN MTi2 (x3)
System 2: Mac Pro (Mid 2010) 3.33 GHz 6-core - 32 GB RAM - OS X 10.9.5 - Magma PE6R4-I - PT HD 6 Accel PCI - PT HD 10.3.10 - 192D I/O - SYNC I/O
EQ3 4 band Steve White Pro Tools TDM Systems (Mac) 1 07-23-2008 03:08 PM
what mic´s to get to mic a whole band hlynur Pro Tools TDM Systems (Mac) 6 12-10-2006 07:42 AM
OT - YOUR best band name(s) graveleye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 39 01-20-2003 12:18 AM
Bussing of 1-band or 4-band EQ TonyR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-15-2002 01:02 PM
One band EQ? sonoma bass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-05-2002 09:08 AM
