Hello I'm sure this question as been ask before but I can' find the thread
I' m trying to setup my Apollo Silver (FireWire) With the The New PT 12 But I get double input (Monitor) when I'm recording. I did a setup for my friend with the new Apollo without any problem |
Is there a way to automatically activate mute on armed tracks when I record ?
There used to be a plug called mute tone....that did this iirc.
But you can also split the Mix and Record faders....and pull the record faders down to infinite - thus muting the track only when in record...and monitor thru the Console App
Just turn on LLM.
Wow ... i' m new to Pro Tools but I have asked questions on other DAW Forum' s and so far this is the Best and Quickest Help I got .... Big Thanks
I Activated the LLM and it's working fine Now ... Thanks again |
Yep Drew for the win.
![]() Quote:
This is what I do. But the thing to keep in mind is you have to record arm the track before you bring the fader all the way down. In the preferences, you have to uncheck "Link Record and Play faders" for it to work right. Avoids having to bother with LLM.
www.HellfireBeats.com Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61, Focal Alpha 80, UAD 2 Apollo Quad, UAD 2 Satellite Quad, UAD 2 Octo PCIe, Neve R6 "Lunch Box", Neve Portico 511, Neve Portico 551, Neumann TLM49 Pro Tools 2018.10 Mac Pro 4,1 (5,1 upgrade), Early-2009, 3.46GHz Nehalem 12-Core, 32GB RAM - OS 10.12.6 13" MacBook Pro, Late-2011, 2.4GHz Dual Core i5, 16GB RAM - OS 10.12.6 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - OS 10.12.6 |
Thunderbolt Connector Apollo 8p Problem | gmu | Pro Tools 12 | 3 | 12-13-2016 02:33 AM |
Apollo - FireWire vs Thunderbolt | mrgroovy | Third Party Interfaces | 3 | 12-20-2015 08:34 AM |
UA Apollo Quad/Firewire -I/O inputs not in Pro Tools.. tried PT mode.. | awritersparadise | Third Party Interfaces | 5 | 12-01-2015 05:45 AM |
Pro Tools 9.0.5 - Low Latency Monitoring problem still persists | xazqe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-02-2011 09:54 AM |
monitoring problem with pro tools and fastrack ultra | bluebearddub | Pro Tools M-Powered (Win) | 4 | 09-09-2008 11:35 AM |
