Old 04-17-2017, 12:27 AM
7thheaven 7thheaven is offline
Default Korg Legacy AAX?
Anyone know any news or work around to get the Korg legacy plugs to work in PT 12?
Richie- 7th heaven
www.7thheavenband.com
Old 04-17-2017, 12:53 AM
Bonehill Bonehill is offline
Default Re: Korg Legacy AAX?
I asked them over a year ago about this & they basically said it wasn't going to happen - it might be possible to get it working via a wrapper such as Bluecat, though I've yet to try it
Old 04-17-2017, 12:59 AM
WarrenG WarrenG is offline
They all work fine through BlueCat.
Best regards
Warren
Website
FaceBook
MySpace
Old 10-21-2017, 08:44 AM
readymedia readymedia is offline
Hey, there!
I have the Korg Legacy Collection working fine under Windows7 64Bit with Ableton9 64bit. It also works fine in stand alone mode. But it is not visible in my Pro Tools 11.3.2. So it is the same problem like mentioned before...
I used the 64-installer for installation. Well they install 64 Plugins or it is just able to run on a 64Bit OS? Maybe the second... ;( The KORG web site says indeed the plug ins are 64bit! So why they work in Ableton 64bit from scratch but not in Pro Tools 64bit?
After installation I found some files like
M1 RTAS.dmp = 500Kb
M1 RTAS.dmp.rsr = 1kb
Wavestation RTAS.dmp = 500Kb
Wavestation RTAS.dmp.rsr = 1kb
here:
C/Program Files (x86)/Common Files/Digidesign/DAE/Plug-Ins
I tried to copy those files to
C/Program Files (x86)/Common Files/Avid/Audio/Plug-Ins
but again no KORG plugins in PT11.x
I can't find something in the 64bit folder "C/Program Files/" except of
C/Program Files/Common Files/KORG/Legacy Cell/
C/Program Files/Common Files/KORG/WAVESTATION/
With something like in each one:
M1 VST.nfo = 1 kb
m1ex.dat = ~56 Mb
Any ideas how to get the legacy collection work under PT11?
@WarrenG:
You mean that you use the Patch Work to load 32bit Plugins into Pro Tools? , right?
https://www.bluecataudio.com/Product...uct_PatchWork/
So PatchWork do the same adapter job like VSL Vienna Ensemble Pro 6, right?
UPDATE: I checked Blue Cat PatchWork (the Win7 64bit-AAX Demo) and it seems to work just fine with the KORG legacy collection.
Greetings, Andreas
me, M6700/i7quad/Win7 + PT11/Ableton
Old 10-21-2017, 04:28 PM
According to Pro Tools 11 Plug-in Compatibility http://avid.force.com/pkb/articles/e...ility/en343311
Pro Tools 11 requires plug-ins to be AAX format and 64-bit.
Also no other Plugins would be recongised in Pro tools 11 (and 12 also).
Ableton 9 (in 64bit Version) accepts VST Plugins in 64bit:
https://help.ableton.com/hc/en-us/ar...ins-on-Windows
So that is the simle reason, why Korg Legacy collection dosn't apper under Pro Tools and why you need such software adapter like Blue Cat PatchWork...
Anyway I'll try with VSL Vienna Ensemble Pro 6 as an adapter, because of 9Gb Orchestra Library and network master/slave-capability for additional ~170 EUR.
Old 10-21-2017, 11:50 PM
deanrichard deanrichard is offline
As someone mentioned earlier, Bluecat Patchwork will allow you to load the VSTi versions of the Korg synths.
Old 10-24-2017, 08:15 AM
WernerF WernerF is offline
Yup, Pro Tools 11 and 12 only use AAX plugins or an AAX wrapper plugin that can wrap the non AAX plugins and make them work in Pro Tools.
Old 10-25-2017, 11:35 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Korgs newest 64 bit update (Your account at Korg)
AU & VST Only
Yes the BlueCat Hosting works fine in the newest Pro Tools
Old 12-22-2017, 10:54 AM
Righty27 Righty27 is offline
New version adds ARP Odyssey and AAX//new UIs coming too! :)
https://www.youtube.com/watch?v=rLyt_46rfsw
http://www.korg.com/us/products/soft...contents=error
Korg shop - https://korg.shop/software/korg-collection-series.html
Upgrade for existing Legacy users @ $50, so less than the $70 for the single ARP.
Old 12-22-2017, 03:18 PM
JGuth JGuth is offline
Korg are promising AAX but it does not exist now, just AU and VST. I would use the AU in Vienna Ensemble Pro to run with ProTools.
HTML code is On
Korg Legacy Collection $100 anp27 Buy & Sell 4 09-08-2015 07:10 PM
korg legacy barry1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-15-2010 12:22 PM
Korg Legacy Collection with PT6.4LE smit1_uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-02-2007 10:12 AM
korg legacy nerd513 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-31-2005 01:35 PM
Anyone using Korg Legacy Plug Ins w/ PT Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-19-2004 02:16 PM
