Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 02-04-2016, 12:19 PM
adam79's Avatar
adam79 adam79 is offline
Default UA Apollo Interface Issue
I using my PT 12.4 setup for the first time in a month; I took a small break to reboot my ears. Anyways, my Apollo interface disappeared from the "Playback Engine" drop down menu. When I cancel out of this window, or open the "UAD Meter and Conroe Panel," I get a pop-up menu informing me that:
"The currently installed firmware is newer than the firmware you are installing. Are you sure you want to downgrade the firmware?"
Also, under the "Interface" tab in [Apollo] Console "Settings," Apollo is written in red (in the "Select Unit" menu). Red text means the UAD link is inactive.
I set everything up the same way as always and I haven't downloaded/installed any updates for the Apollo, OS X, or anything else. The UAD Powered Plug-ins version I've been running is: 8.4.
Any suggestions on how I can get this up and running again.
Thanks,
-Adam
Old 02-04-2016, 02:47 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: UA Apollo Interface Issue
Apollo connected via what?
FW? are you using the correct FW card? have you ran the firmware updater (which is really erasing the auths from the previous owner)?
What version of OSX?
Daniel
Old 02-04-2016, 06:53 PM
adam79's Avatar
It turns out that I downloaded the Firewire version instead of Thunderbolt.
UA Apollo Quad - FW interface YYR123 Buy & Sell 13 12-07-2015 09:31 PM
Mix Engine issue with Apollo 16 awakenedgroup Pro Tools 11 0 08-07-2015 06:06 PM
UAD Apollo Twin Solo Interface & Pro Tools briaboy Third Party Interfaces 12 05-04-2015 10:06 AM
Issues After Updating UA Apollo Interface viktor99 Pro Tools 10 0 11-03-2013 10:36 PM
PT11 compatible UA Apollo interface? djkikis macOS 4 07-05-2013 07:44 PM
