GPO for "Recording" Red light. S5
On my SC264 I have GPIO's connected to the TT002B card. I have created 2 GPO events in eMix 6.03.
I have assigned Record OFF to GPO1 open on TT002 I have assigned Record ON to GPO1 closed on TT002 On the DB37 connector Pin20 is GPO1 and Pin36 is common Connect a multi meter to pin20 and pin36. Press record On/Off on the 401 or Pro Tools I get continuity On/Off because the GPO is a contact closure. This is good. Now I need to connect Pin20 and Pin36 to an external 12vdc relay that will power up the Recording red lights and lock the exterior doors. Does anyone have a circuit diagram specifically showing connecting GPO's to external relays? Obviously the GPO cannot power the 12vdc relay so a 12vdc source must be placed in line between Pin20 and the coil side of the relay but this shorts out the TT002B internal relay essentially breaking the 401 transport but resolves after a reboot of the SC264. |
Re: GPO for "Recording" Red light. S5
Ok I figured it out. Since you cannot supply dc voltage to the TT002b card you must use a relay they excepts dry contacts.
I purchased a "RIB01BDC" from Amazon. It has a power input of 120vac with dry contact inputs with 20am 120vac relay contacts. The relay contacts can can switch 12vdc as well. You connect the dry contact inputs with the GPIO card on the back of SC263/264. I now hav red lights and door locks when recording! |
Mbox Pro 3 blue light stays on but has the status of "Hardware not connected" | Focuret | FireWire & USB Audio Interfaces (Mac) | 1 | 01-15-2014 12:18 AM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
"hardware not found"...power light solid. | cjdude | macOS | 16 | 05-28-2012 01:05 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
"Green Light" from Apple = New Macs Qualified? | fresh_meat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-02-2002 05:09 PM |
