Drag and Drop Audio from Workspace issue
Hi.
Pro Tools Ultimate 2019.5.0 on iMac Pro Mojave 10.14.5 I am trying to drag and drop a bunch of audio files which are numbered 1 - 40 into a template with corresponding tracks also numbered 1 - 40 and for whatever reason, whenever I do this Pro Tools seems to scramble the order so that I have to go through and manually move every audio file to the track to where it should be. It doesn't matter if I grab all 40 tracks or just 3 of them....they don't stay in alpha/numeric order. Huge time killer. Say for example I have 5.1 interleaved audio files with the following file names: Stem 1 Live Brass Stem 2 Synth Brass Stem 3 Live Strings Stem 4 Synth Strings Stem 5 Hi Perc Stem 6 Lo Perc Stem 7 Synth Perc Loops In the workspace they are in numeric order Stem 1 to Stem 7, top to bottom. Grab all 7 of them together and Drag/Drop to Pro Tools Session with 7 corresponding 5.1 Audio tracks, also numbered 1 - 7 (but track names should be irrelevant). This is what I see: Track 1 Live Brass = Stem 3 Live Strings Track 2 Synth Brass = Stem 1 Live Brass Track 3 Live Strings = Stem 5 Hi Perc Track 4 Synth Strings = Stem 7 Synth Perc Loops Track 5 Hi Perc = Stem 2 Synth Brass Track 6 Lo Perc = Stem 4 Synth Strings Track 7 Synth Perc Loops = Stem 6 Lo Perc Seems pretty random, but it is consistent insofar as the "scrambled" order is the same every time if I Quit Pro Tools and then re-open the session and do it again. Also, it doesn't matter if I only grab, for example, any three consecutive Audio files...they show up out of order top to bottom in the Pro Tools Session. Anyone see this and know what's causing it? I've trashed Prefs/rebooted and restarted protools and still have the issue. Any ideas would be much appreciated. |
Re: Drag and Drop Audio from Workspace issue
Hi, Does it matter if you drag them from a folder or from the clips bin?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
From a folder in the finder or from the clips bin it seems to work as I would expect.
That said, I was hoping to find a fix for the problem and not a work around.... |
On my system, PT10, when I drag a clip group from the workspace, only a few of the tracks come onto the timeline, but then if i re-drag it from the clipbin, its proper...
www.kfaudio.ca |
If it is a bug then fix would be newer PT version where the bug has been squashed. As you are on Mojave, try 2019.10 instead of the now current 2019.12 which is released for those who need to run Catalina. Some time soon 2020.x should be out too. If that doesn't help contact Avid Support and explain the situation you think is a bug.
Oh I wasn't thinking of it as a workaround - that's how I usually work.
Run as administrator issue - either drag and drop or elastic audio broken | tcolvinMS | Pro Tools 11 | 10 | 02-27-2015 08:17 AM |
Can't Drag and Drop from Workspace | blizzard | Windows | 8 | 02-13-2015 08:39 PM |
Drag and Drop from Workspace VERY Slow | gfcurtis | macOS | 36 | 01-29-2015 09:08 AM |
WorkSpace Drag and Drop Not Working in PT11? | quantise | Pro Tools 11 | 0 | 08-14-2013 07:29 AM |
Workspace drag and drop issue | ZeSnail | Post - Surround - Video | 3 | 12-25-2011 08:11 AM |
