Old 09-11-2014, 01:38 PM
inky inky is offline
Default D-Command Firmware update backwards compatible?
We are operating a dual boot system with one setup using ProTools v9 / Snow Leopard and the other using ProTools 10 / Mountain Lion. We are asked to update the D-Command Firmware when we go to Preferences in ProTools v10, but hesitate to do so for fear of losing compatibility with our ProTolls v9 system. Can anyone confirm that we can update firmware without a hitch? For now it seems to work fine with the old Firmware.
Thank you.
Inky
  • Computer model and processor speed - 2 x 2.4 GHz Quad-Core Intel Xeon
  • OS version - v10.6.8 and v10.8.5
  • Avid hardware model – HD3 Accel, D-Command, SYNC I/O, 196 x3, 96i, XMON, PCIe Expansion Chassis
  • Pro Tools version - v9.0.6 and v10.3.7.296
  • Amount of RAM installed - 12 GB 1066 MHz DDR3
  • D-Command Firmware: COMM v9.0.1.1 / MOTOR v9.0.1.1 / XMON v11
Old 09-11-2014, 03:12 PM
Craig F Craig F is offline
Default Re: D-Command Firmware update backwards compatible?
most of the time it's fine
wost case 9 will want to reinstall the old firmware
Thank you,
Craig
Old 09-18-2014, 08:46 AM
Thanks, Craig.
It sounds like we have nothing to lose and can revert back to 9 Firmware if it's acting funky in any way.
If we do need to revert, is the correct Firmware installed and available on our Protools 9 system already or will we have to find it elsewhere?
Thanks again,
Inky
Old 09-18-2014, 01:35 PM
yes, the correct firmware in in the 9 folder
Thank you,
Craig
Old 09-18-2014, 01:48 PM
Good deal. Thank you very much for your help, Craig.
command 8 firmware update for Pro Tools 9 matt_the_manic macOS 0 01-06-2011 05:00 AM
Are Firmware Updates backwards Compatible? teacherman Tips & Tricks 1 05-03-2010 09:49 AM
Command|8 offline + impossible to update firmware El Steffo ProControl, Control|24, Command|8 12 05-31-2008 01:45 PM
Is firmware backwards compatible? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-26-2007 08:52 AM
002r Firmware Update w/PTLE7(backwards compato) whtrabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-09-2005 02:42 PM
