Old 09-21-2013, 04:16 PM
K Roche's Avatar
K Roche K Roche is offline
Default Who is Running PT 11 HD Native successfully
I am finally done with my projects that I was not willing to try upgrade during.
I will be upgrading My OSX ilock and PT 10 to 11
So I am curious what configurations of OSX and PTHDN 11 are people finding stable. Thanks, Kevin
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 09-21-2013, 04:51 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Default Re: Who is Running PT 11 HD Native successfully
Mine is generally quite stable in PT11, but there are some quirks on the vision side of things. If I wasn't doing post I would have made the full switch by now.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 09-21-2013, 05:41 PM
K Roche's Avatar
hey thanks, Kev
System :
Enjoy the Journey
.... Kev...
Old 09-22-2013, 12:14 AM
Jack Ruston UK Jack Ruston UK is offline
I've been starting to run it for a few things and have found it very good. The problem is that because we're still waiting for quite a few plug ins, it's harder to run 'proper' sessions on it. Therefore it's really hard to comment on how stable it really is, because after all it's often the plug ins that cause issues. So from me a 'Yes' but with that caveat.
Jack
Old 09-22-2013, 08:27 AM
Drew Mazurek's Avatar
Been starting every project on 11 for the last 6 or 7 months and then moving to 10 for mixing. In this limited capacity 11 has been great. Probably the best .0 release PT has had. Granted, it is limited use for only recording and overdubbing.
www.drewmazurek.com
Old 09-22-2013, 10:58 AM
Bookerv12 Bookerv12 is offline
It has taken a couple of months, but we have switched completely over from an HD 4 accel TDM system.
I still run into random plugins that we still must upgrade, but so far, solid as a rock.
Buffer settings are new to us, but it works really well.
Pro Tools 10.
Until 11 opens up a little more.
bookerv12
Old 09-22-2013, 01:42 PM
K Roche's Avatar
hey thanks guys
So I am assuming the start in 11 then mix in 10 is only really to gain the use of RTAS plugs that are not yet ported to AAX 64?
And not some actual mixing or editing thing per se yes ?
I since basically I use the bundled PT and my Waves Diamond and some Slate I should be good to go
System :
Enjoy the Journey
.... Kev...
Old 09-22-2013, 07:00 PM
syMPh syMPh is offline
i've found melodyne's latest release causes audio to stop after a certain amount of plugins have been reached (something like about 15 or so) ... which is less than i could get in 32 bit land... must be a bug, anyone else see this happen?
Old 09-22-2013, 09:28 PM
zion zion is offline
Jack
+1
Old 09-23-2013, 02:54 AM
P_J P_J is offline
I've been working with 11.0.2 since Waves AAX64 was released. Not a single crash and everything seems to work fine except importing OMFs. Fans are running higher rpm with 11, even with those sessions where CPU usage is smaller. Could be the new video engine. Now when Izotope RX is also AAX64, I think I'm not going back to ten anymore (oh wait, still have to import OMFs in 10).
Is any one running i7 970 successfully with PT9? Violet Windows 2 05-11-2011 05:00 PM
New iMac i7 successfully running PT 8.0.3 (so far) Zooce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 03-30-2010 06:52 PM
anybody running EastWest's Fab Four successfully on PT8/Pc? keithl Virtual Instruments 0 12-01-2009 06:20 AM
Anyone successfully running 10.4.11 (7.3.1cs5 or 7.4)? jessestern 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-27-2007 06:22 PM
Is anyone running 5.1 on OS8.6 successfully? marc@soundpost Tips & Tricks 7 06-26-2001 03:51 PM
