Old 06-23-2013, 04:51 PM
fastermaster's Avatar
fastermaster fastermaster is offline
Default Problem PT11 MAC stuck in "Playback Engine" selection reload loop
If I use any NON Avid interface everything works beautifully.
When I try to select "HD NATIVE" in "Playback Engine" I'm asked to reload the program to use the new engine and after reloading PT11, it keeps asking me to reload the program again.
I'm using a PRISM ADA8XR and a 96 i/o connected to the slave port , both of them are wired connected to PORT1 on the Native HD card.
Anyone with the same problem?
Matteo FasterMaster Cifelli
Producer-Engineer
Old 06-23-2013, 06:21 PM
feliponk's Avatar
feliponk feliponk is offline
Default Re: Problem PT11 MAC stuck in "Playback Engine" selection reload loop
Press "N" when loading and see if it fix the issue.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Custom Mac Pro OSX Sierra | Windows 10 Pro 64 | ProTools HD 2019 | Pyramix XI | Merging HAPI ADA8 | MBox 3 | UAD Quad PCIe | Avid Artist Mix | Kali LP-6 | Presonus Temblor 10 | Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 06-24-2013, 05:27 AM
No...
I'll try to connect it to an OMNI interface later.
Producer-Engineer
Old 06-28-2013, 05:28 PM
I cannot believe I'm the only one with this problem...
It also happens under Windows 8 with an OMNI and the same HD NATIVE card...
Producer-Engineer
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 11:10 AM
Pro Tools 11 stuck on "Initializing Audio Engine" AudioDrummerGuy Pro Tools 11 10 01-19-2014 01:47 PM
"Playback engine does not support 44.1 PROBLEM adamfrey Pro Tools 11 11 11-05-2013 12:47 PM
Whoever gets PT11 first, please post if "Edit Window Follows Bank Selection" is fixed Focuret macOS 0 04-07-2013 07:08 PM
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 beasleymusic Pro Tools M-Powered (Win) 1 04-02-2011 04:17 PM
