Old 10-10-2008, 07:27 PM
Shawnblack Shawnblack is offline
Default Reinstalled Pro tools and Reason...Need Help
I recently upgraded my PC and I reinstalled both pro tools and reason and now Reason won't show up in my plugins list...
Also, my click track will not put any audio out...Any reason why that would be working?
Old 10-10-2008, 07:58 PM
JWalkerPostAudio JWalkerPostAudio is offline
Default Re: Reinstalled Pro tools and Reason...Need Help
I once had a similar problem with the Reason. I think what happened was my registry cleaner took out a required script. Check your plug-ins folder for a file titled something like digirewire.dpm. I forget if it's actually .dpm or whatever and I'm away from my system to check but I know I was missing my digirewire file when I had the issue (this would also mean any other programs installed that use rewire should be missing like abbleton live or melodyne).
My solution if this is also your case(there may be a better one): uninstall pro tools completely, you can keep reason installed 'cause that shouldn't matter, then reinstall once again. Oh and have your activation number ready cuz you'll need after the reinstall.
Justin
Old 10-10-2008, 08:04 PM
So I wouldn't need to reinstall reason to get that dpm file back?
Old 10-10-2008, 08:23 PM
I don't think so because it sounds like a rewire thing and that file comes with the PT install. Is that what you are missing?
Old 10-11-2008, 06:33 PM
Parisstudio Parisstudio is offline
Just had the same issue, what I did was went into add/remove and selected pt. I then selected repair or whatever else can't remember and it reinstalled pt and then everything works fine.
Just reinstalled PT 8 and now for some reason everytime I close and reopen PT.... Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-06-2010 10:51 PM
lost mbox 2(midi interface_ when i reinstalled Pro Tools HD jjmoon Pro Tools TDM Systems (Mac) 2 08-16-2009 11:06 PM
So.. I just reinstalled my whole system.... Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-27-2006 05:28 PM
Reinstalled - Now What? PTUSR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-09-2005 05:59 AM
Help please. I reinstalled 10.3.X and 10.3.8 combo Dr.Groove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-03-2005 05:06 PM
