Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 06-08-2012, 08:05 AM
passion4music passion4music is offline
Default Amps necessary for FastTrack USB?
So I own a Fast Track USB interface. I got a super dynamic mic. And I was wondering if it is necessary to have an amp connected to my FT. I got problems recording vocals, my voice always seems to be faint until i turn my gain knob over a half and a quarter, thus hearing white noise as well.
Any advice would be great.
Only please don't tell me to invest a better mic, because I do not have the time or money to invest right now.
Thanks.
Old 06-13-2012, 02:35 AM
PD-John PD-John is offline
Default Re: Amps necessary for FastTrack USB?
A dynamic microphone is significantly less sensitive than a condenser, so it's output is lower in level. This is why you're having to turn up the gain on your Fast Track a lot, thus introducing the microphone preamp's noise (preamps on interfaces typically get a bit noisy when turned up). Buying an external preamp with a lot of clean, quiet gain will solve your problem.. but if you don't want to make any investments at the moment then careful use of a gate/expander when mixing should hide the noise sufficiently.
Old 06-13-2012, 04:21 AM
hooksound hooksound is offline
Solution 1: A good large diaphragm condenser mic. SE and AKG both has good mics that goes for ~ $100-120.
Solution 2: Record in the comfort zone gain wise and then insert the Trim plug-in on the channel in Pro Tools during mixing.
Mbox 3 Pre amps vs. External Pre amps? evanbgrove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-10-2011 05:21 AM
Mbox 2 pro... Pre Amps (vs) 003 Pre... Amps Norm Mix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-24-2009 02:37 AM
Fasttrack Pro Hum! ChitySomapala Pro Tools M-Powered (Mac) 0 07-25-2008 06:48 AM
Fasttrack PRO greg1 Pro Tools M-Powered (Win) 9 04-29-2008 05:55 AM
Fasttrack ikke Pro Tools M-Powered (Win) 0 12-11-2005 08:17 AM
