Old 09-18-2022, 07:41 AM
khester khester is offline
Default D Show Noise in FOH-connected sources
All, I'm posting due to an ongoing issue I'm having with one of the older D Show units we have. Looking to upgrade soon, but still would like to get a little more time out of this system if possible. We are experiencing what sounds like digital noise on a few channels that are patched (analog) into the FOH rack.
Example of the noise can be seen/heard at the link below. The noise shows up on 4 analog inputs from a Focusrite unit we use for playback, as well as in an analog insert path we are using. Insert path is FOH 16, and the other four channels are routed in FOH 11-14. We've done the maintenance on this FOH rack, and even changed the power supplies - all to no avail in alleviating this issue. Any insight or thoughts would be welcomed!
https://www.dropbox.com/s/f9b2r8td7q..._5563.MOV?dl=0
Mbox led light show - hardware not connected tomvdd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-04-2013 09:16 PM
Rather Spectacular Mid-Show White Noise Attack! Chris Johnson VENUE Live Sound Systems 2 03-16-2011 05:22 AM
Plug-In Noise Issue with D-Show software 2.8.x DigiFieldService VENUE Live Sound Systems 4 05-07-2010 07:28 AM
Big noise when rearranging tracks in the Show/Hide column soundboy35 Pro Tools TDM Systems (Mac) 2 09-11-2007 03:43 PM
Sources Connected to Inputs, but No Sound egrantley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-18-2003 06:01 AM
