Hello, i've try to link matrix 1 and matrix 2 to make a stereo out. I assign master left on matrix 1 and master right on matrix 2, when i link it, the matrix 2 as the master left assign. Is there a bug or do i make a mistake ?
Thank Rémy |
Hi Remy,
I think I see what you are doing. Each of the 12 input sources within each Matrix mixer is shared so whichever input is assigned to Input 1 on Matrix 1 will also be the input 1 on all other Matrix Mixers. Your Main L and R are by default assigned to inputs 9 and 10. To do what I think you're trying to do try the following : - under Options > Busses : Link matrix 1 and 2 (sounds like you already did this) - under Outputs, select Matrix 1. Since you linked Matrix 1 and 2 you should see a pan pot on every input channel. By default inputs 1 - 8 are assigned to Group outs 1 - 8. Inputs 9 and 10 are assigned to Main Left and Main Right. - Pan input 9 hard Left and input 10 hard Right. Set both input levels to 0 dB and switch the input source ON (You can also link the levels for these inputs by checking the link box under inputs 9 - 10) - In the patchbay > Outputs : assign a physical output to Matrix one and another one to Matrix 2. Any Matrix input source panned Hard Left will only come out of the output assigned to Matrix 1 and anything panned Hard Right will only come out of the output assigned to Matrix 2. I hope that makes sense. Let me know if you have further questions. Thanks
Chris Lambrechts Applications Specialist- Live Sound |
Are you using any PQ sends?
they are just stereo a Matrix |
but there´s no delay for pq. right?
Hi Chris Thank for the info, i try it and it work's very well
Rémy Venue D-Show, Ver. 3, 5x DSP card |
protools 11 demo link to old version | studiosus | Pro Tools 11 | 1 | 02-05-2014 01:40 PM |
Pro Tools Playback Issues at 88.2 with Delta Link / Alpha Link - Any ideas? | azirkin | macOS | 1 | 01-17-2012 02:30 AM |
Latest version of Satellite Link? | 1m1 | Pro Tools 9 | 0 | 08-14-2011 02:51 PM |
LINK HERE!! - ERXP is now version 2.0.1 | TheChimp | Eleven Rack | 1 | 04-03-2011 02:53 AM |
Does anyone know the link to download the 001 XP version | Obscene | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-20-2003 01:35 AM |
