differnt megaherz rates..44k..48k..96k
Hi gang..can anyone explain to me what the differnt mega herz...44k..48k..96k etc will do when u r recording?...my buddy has a mbox2 pro and says its actually makes the recording brighter on audi but it will eat the cpu on midi..is this true...ty....he uses the upper 96k and 24 bit for recording.
Re: differnt megaherz rates..44k..48k..96k
were to start?
it's not mega(M) it's kilo(K) look up Nyquist http://en.wikipedia.org/wiki/Nyquist...mpling_theorem for starters
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Hey Barry,
The first question I would ask is, what's your endgame? Meaning in "the old days" when people used to buy CDs to listen to music, 44.1kHz was your sampling rate and 16bit was your bit rate. For a higher frequency response (in the digital world this is your sample rate) you could double it to 88.2kHz. Now if you are in Film/TV post production your endgame is going to be 48kHz (confused yet?) Now in the HD age, we've doubled that resolution to 96kHz. (or for really good frequency response that only dogs can hear - 192kHz) Basically it's all multiples of either 44.1kHz (CD standard) or 48kHz (Post Production standard) 'Course if you really want to get confused, I could start going into pull-downs & pull-ups.... :) |
well craig thanks for a long winded no help answer..Im sure if u needed help to something u needed a answer too...u would appreciate a basic answer..not a run around....so in plain english..if someone can give me a answer on what can one expect if they chose the higher k when recording....u had your shot craig...dont bother replying.
marvschlom ty...i understand what u r saying...u said the same thing i told my buddy but on his assistence..he states recording at 96 would give a cleaner recording..yes i know about the k on a cd..i tried to explain that to him....he is in the belief that if u record at 96k then when u bounce down to a cd it would give a cleaner performance..even if its 44k...one other point i wish to ask u..if u record at the higher levels does that take more out of the cpu or memory?....ty marvschlom..i appreciate ur response to my post.
This answer is not as simple as you might think.
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 |
I wholeheartedly agree. If you are doing anything with digital audio, you really should know and understand the Nyquist theorem. (Learn as much as you can, that's my theory)
apologies to craig....
There's a reason it's called engineering.
differnt waverform zooms in one session? | murks | macOS | 4 | 04-27-2011 04:40 AM |
Does LE sound differnt than HD | jlo1182 | Pro Tools TDM Systems (Mac) | 16 | 11-28-2005 11:38 AM |
Differnt motherbaord with SAME chipset? GA-7VT600 | Shaun.b | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-09-2004 03:57 AM |
Import Plugins onto tracks from differnt sessions? | Matt Whritenour | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 01-23-2004 03:49 PM |
Comparing Bit-rates, Sample-rates, and convertors - Telling the difference? | stoogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-05-2003 08:36 AM |
