Old 04-12-2012, 08:54 AM
sytrusze sytrusze is offline
Default MIDI ghost in Pro Tools
Dear members,
seems like i've got a MIDI ghost in my PT. Yesterday i made a project, i have 1 Instrument track with Xpand2 loaded. I've recorded a simple 2 bar loop with my midi keyboard. I saved the project and today when i opened it plays a chord that isn't even there. I deleted all regions from the track AND region list, but the sound still keeps playing even though there aren't any regions.
It seems like it plays a chord from another region from another track. How is this possible, what can i do to make it go away? Thanks
http://f.cl.ly/items/0F051d3x3R3L2c2...55.03%20PM.png
Old 04-12-2012, 12:44 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default
U might want to check in the midi editor screen - it may be way high or way low notes -
Take the xpand insert off the instrument track and play back the section of audio - u should se midi action if there is something there
Reinsert xpand - what happens ??
Create another instrument track - insert xpand ? What happened ??
If Push comes to shove - delete the first and go with the second - process of elimination kind of deal !!!
Daniel
Old 04-12-2012, 01:01 PM
Default Re: MIDI ghost in Pro Tools
First of all, thanks for your reply!
Normally you would do this by double clicking a region, but since there are no regions on the track at all, i can't do this. To be sure i've selected the notes view on the track, but there were none.
So i did, absolutely no midi action strangely but you actually can hear the chords.
No mather what plugin i reinsert, Xpand, mini grand or Vacuum, the chords are still playing.
If i do this, everything works normal, just like expected :)
I definitely will, i'm just curious about the cause so i can prevent it in the future. It's kind of strange issue might be a bug, or just a simple mistake that i'm overseeing at the moment.
ps. I've created a new MIDI track with Xpand inserted beneath the GHOST MIDI track and opened up the mixer. I've compared everything, outputs, inputs but could find anything.
EDIT:
I just noticed something! On MIDI track 7 (Inst 7) i have a region with those exact chords that i was hearing. If i delete the region, the ghost sounds also disappear....that means that the Ghost midi track HAS TO BE linked/routed/connected to MIDI track 7 in some way because it's playing its notes.
http://f.cl.ly/items/36413n1p0p081F3...10.47%20PM.png
Old 04-12-2012, 09:47 PM
YYR123's Avatar
Default
U should be able to toggle back to the midi editor with the control +\- key right
Glad u found it
Daniel
Old 04-13-2012, 12:42 AM
onessela onessela is offline
I had same problem. Try to duplicate the track with ghost notes and then delete the original one. Does the new track sound good ? This makes me nervous, as I suspect something is going wrong under the hood....Actually when I have these kinds of problem, I experiment also PT hangups
Regards
Old 05-20-2012, 12:06 PM
Flyingonempty Flyingonempty is offline
I have a similar issue i play midi to Xpand2 and it sounds good as it goes down then on playback some notes do not play (I see them) and others are lacking sustain. Sounds like poooo???? I have changed my settings to 3 Cpu's 1028 on the buffer and looked at the midi editor....? no issues there ao what is going on?
Further i change to grand pno plugin and same or some time not same notes doing the ghost thing..I see midi on playback in the ins. area of the track but sound does not match. I AM STUCK NO WORK FOR US TILL WE GET THIS SORTED ...any ideas?
Thanks
Old 05-20-2012, 12:09 PM
OK now i have tryed the db33 on the same trk and get what sounds like someone tapping knuckles on a wood box???? ouch what s this doing????
Old 05-20-2012, 12:16 PM
This is getting weard I retracked a clip using db33 as the sound souce and got a oK recording in midi whan I pluc=ged in the grand pno in to that midi track it sounds like the attack is off as in the WHO almost??? I think the Xpand is trashed and so might be the other AVID plugins plz if you have a clue let me know.....
Old 05-21-2012, 09:34 PM
MidnightFlyer MidnightFlyer is offline
Is it possible that you have something previously recorded on an alternative playlist? This will happen sometimes when a track is empty but there is a completed track on the playlist that is hidden because you started a new playlist.
002 ghost MIDI notes Thuneau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-16-2010 02:30 PM
Midi ghost notes lbar11 MIDI 3 10-31-2009 06:04 AM
Soundcraft Ghost with Pro Tools - transport/MIDI control? bwherry General Discussion 0 02-05-2003 01:43 PM
Ghost midi regions appearing jackruston MIDI 4 07-18-2001 02:30 AM
Ghost Midi regions appearing Barry Young Pro Tools TDM Systems (Mac) 0 05-27-2000 01:29 PM
