Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 03-11-2016, 02:50 AM
ely75 ely75 is offline
Default CM408T Beep problem
Hello Guys
I have a 5MC with 2 CM408T modules
Since this morning, one of them beep (long and repetitive beep) and does not start
Power is ok, (first fader is on), and i don't understand where is the problem
Is it a ram or rom problems ? Have you ever had that ?
Thanks for your response
Gerg
Old 03-11-2016, 05:40 PM
H.G. Hollans's Avatar
H.G. Hollans H.G. Hollans is offline
Default Re: CM408T Beep problem
It might be the RAM. That can be found on the SBC/motherboard which is attached to the panel behind the display.
You might want to try re-seating the RAM, or replacing it.
Also if you have a monitor available, you could try connecting that to the VGA connector on the back. That could possibly yield some clues.
It's possible the SBC has failed, but we do have replacements available.
Old 03-15-2016, 01:53 PM
Hi
Just to say that i replace the battery and it's working
Thanks
Regards
delivering a short movie beep or not beep alidav macOS 9 12-04-2014 05:26 PM
How create ADR beep region? unclytwin Post - Surround - Video 5 06-08-2011 04:15 PM
beep beep? manis Post - Surround - Video 11 03-31-2007 10:52 AM
Beep sound on 7.3 Makis Pro Tools TDM Systems (Mac) 3 01-12-2007 09:29 AM
Software that put's "beep's" in the song. jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-07-2004 08:59 AM
