#81
Re: No Access to MIDI Patch Names File in PT HD 11.1
Fixed in 12.1√ Yea!
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
#82
Re: No Access to MIDI Patch Names File in PT 11.1 -12.0
AWESOME!!!!!!
I have been cursing my outboard stuff without this! |
#83
MIDI Patch List working along with Input Monitoring for outboard MIDI gear - be still my heart. I'm still PO'd that they didn't fix it in 11.x though.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
#84
this way they can tell you it is a new feature ... :) happy to hear that issue is solved ... and what the hell do you have for a headset A Dave Clark Helicopter Headset
#85
Just a FYI - you may have to delete and recreate your devices in AMS in order for patch lists to work in 12.1 - I had to and now everything shows up correctly.
#86
Really?? I'm skeptical - still on PT11.3.1 and am about ready to pull the plug on about 20 years of ProTool use for things like this.
My question is: can you *CHANGE* MIDI files. Some of my gear - like my trusty VFX SD, has cartridges and I have separate patch name files for each. If I'm locked into one - then I'm right back where I started with setting them up in PT 10 to use in PT 11. |
#87
I tried this and still can't get them to stick in 12.1. I use the 'change' button on the patch list window to import the correct midnam and it works... until I close the patch select window. If I open it again to select a new patch I have to repeat the process every time.
#88
That's what I suspected.
Sigh. Man - this is going to be painful - but I've got to get off this ProTools train - or at least give it a good shot. |
#89
I've had problems in 12.1 with devices that I've created that had only one 'Receives' channel selected in AMS. After deleting and recreating with two or more 'Receives' channels things appear to be working properly for those devices. A rather odd problem.
Jawknee, I can't comment on the ability to load different patch files for cartridges, but if that doesn't work would it be possible to create one patch file with multiple banks? If you're familiar with Cherry Picker, the developer provided a link in a thread on Motunation to a version that works on the recent OS releases. It's a little quirky, but does the job.
Access VirusB patch names..... | dubhausdisco1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-27-2006 07:12 PM |
MIDI Patch Names | bigbrendan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-04-2005 01:27 PM |
MIDI Patch Names & PT6.4.1 Mix | Mount Royal | Pro Tools TDM Systems (Mac) | 0 | 12-15-2004 05:25 PM |
Midi Patch Names in PT6 & OSX (How)?? | Earthling | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-03-2003 11:03 AM |
PT5 & OMS Names Manager (MIDI patch names) | Baron Von Deca | Tips & Tricks | 0 | 02-17-2000 03:55 PM |
