Do you guys plug the xlr straight into the main outputs or do you take a DI from the one of the amp outs? If you use the main outputs, do you plug into the soundboard at line level or mic level? also, are the amp outputs line level, or does the DI automatically make it mic level? thanks in advance!
I go direct from the XLR to the board. I guess I don't know what they do with it from there........
The 11R XLR outs are too hot for the XLR ins on most FOH consoles - the 11R outs are line level, and most boards' XLR ins are mic level. Boards that do have line in are usually 1/4" TRS. You can buy an adaptor to convert XLR to 1/4" TRS, if you can talk the house soundman into re-patching his board for you...
I use Output to Amp 2 (on the back) to a DI, with the XLR going to my K12.. |
XLR to Line in here. Sounds great
1/4" that is... don't want any nasty phantom power surprises :)
thanks guys, one more question. when recording for other artists, like on their own system and computer, do you use the xlr outs to the console, or do you still use the usb?
I've always run the XLR outs to the stage box. I've never encountered a situation where the house board can't pad the line-level signal or turn off phantom power.
I carry a pair of 1:1 inline transformers and a pair of short XLR cables just in case I run into a situation where I do need to worry about isolating phantom power. I suppose I could also carry a couple of inline attenuators to placate the sound guy who doesn't want line-level signals on his snake. (As noted, I have yet to run into either situation.) |
I go send Left XLR to my Mackie, and Right XLR to the house. I make sure the soundguy knows the signal is line level and Not mic level, and that he should use little to no gain on my channel ( to get rid of any hum on the line). I have had soundguys in the past complain that my rig is causing unnecessary hum and that I should fix it when they are setting it up wrong on the board.
Self Built PC: Core i5 3570K @3.4 Ghz | Asus P8Z77-V LK 8 Gigs Corsair XMS 1600 | XFX HD4870 120GB OCZ Agility 3, 2 TB WD Green Windows 7 Home Premium 64bit Pro Tools 8.0.5 M-Audio Keyrig 49 Eleven Rack w/ERXP FCB1010 | Mackie SRM450v2 | Taylor 314ce | Ibanez RG321MH | ESP Horizon NT-II DSBS |
How to use outputs 1-2 on Digi003 without getting main mix? | se.audio | Tips & Tricks | 10 | 12-21-2020 10:16 AM |
Amp outputs same level as Main outputs? | DonaldR | Eleven Rack | 0 | 02-07-2013 02:50 PM |
Nothing coming out of 11R Main Outputs | adjectives | Eleven Rack | 0 | 05-07-2012 02:01 PM |
Eleven Rack Main Outputs | C0ldFart | Eleven Rack | 9 | 11-07-2010 03:09 AM |
Use DIGI-001 as main outputs for Mac? | birdFEEDER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-14-2003 01:02 AM |
