Old 07-21-2007, 04:40 AM
roller roller is offline
Default Digi 001 Direct Outputs setting
Hello,
I have a question regarding the DIRECT OUTPUTS (preferences/operation).
At the moment I have only two active monitors connected to the digi 001 but I'm thinking to add a few more to do surround or preparing a surround mix with the digi 001.
I'm wondering if it's possible to control the volume of the connected speakers to all of the analog outs by turning the Vol-knob on digi 001 ? Or is this knob controlling the volume of speakers connected to the monitor-output only ?
regards
Roller
MBox|PTLE6.4cs9|ASIO 6.1.1|WinXPPro SP2+
ASUS P4C800-E Deluxe|P4-3GHz-FSB800(HTon)|2GB RAM|IDE160GB+IDE250GB+2xSATA500GB(no RAID)
Old 07-23-2007, 09:05 AM
Mikeren Mikeren is offline
Default Re: Digi 001 Direct Outputs setting
The volume knob controls the monitor outs only.
MR
Learn to listen. Listen to learn.
Old 07-23-2007, 03:25 PM
I discovered that the described feature (direct output selection) i talked about is not available where the digi 001 getting-started-guide described it to be. I was just leafing in that guide, where the idea crossed my mind, if I could control a surround setup with the volume knob. Thank you for your answer anyway! But...
Do you know if the direct output / stereo mix selection is still available in PTLE6.4 ? The Guide described the 5th MAC version...I'm wondering if I could a surround mix on ptle and pass it over to a Mix or HD system and what I have to watch out by doing so ? Is there a description/howto or so available anywhere you know of ?
Mbox Pro3, 8 DIRECT OUTPUTS???????? Clavioline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-07-2012 01:08 PM
Those who go direct, Main outputs or DI box? Jd0g33 Eleven Rack 7 11-01-2011 09:27 PM
Setting outputs for an NRV-10 mrbelv Pro Tools M-Powered (Win) 2 07-13-2008 10:19 AM
setting up direct connect bjorn for a reason Pro Tools TDM Systems (Mac) 0 02-04-2001 02:46 PM
Cascading direct outputs in mixer? D Pinder Tips & Tricks 5 03-17-2000 04:41 PM
