Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 03-19-2019, 02:34 AM
StudioXander StudioXander is offline
Default Avid dock fader noise
Hi everyone,
I bought a new avid dock a few weeks ago. While using it I though the fader was making more noise than it should, it's about as loud as the artist mix faders. So I got a replacement unit, but the fader makes the same amount of noise as the previous unit.
I've made 2 quick smartphone videos of the sound.
https://www.dropbox.com/s/c3uuyayb5w...r%201.mp4?dl=0
https://www.dropbox.com/s/f6sr6goab4...r%202.mp4?dl=0
Does anyone recognise the sound? Or should it be smoother and lower in volume? I'm not sure if I put my expectations too high..
The touch response and movement work fine.
Thanks,
Sander
Old 03-19-2019, 03:13 PM
reichman's Avatar
reichman reichman is offline
Default Re: Avid dock fader noise
Yep. Familiar. The S3 is a little quieter, D-Command and S6 are a lot quieter. You get what you pay for. I made a soft key for Eucon/Global/Faders Off for when you're doing critical listening. But they only bug me during slow fade-outs.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 03-22-2019, 02:27 AM
Thanks for reply!
Several sources told me this is indeed normal behaviour. Too bad the fader is not really better than the avid mix ones.
Im going to add the faders off soft-key, thanks for the tip!
Dock fader sucks! Mike Landolt Avid S1, S3, Dock and Control 17 04-12-2018 09:18 AM
Dock's fader - Mechanical noise ets Avid S1, S3, Dock and Control 1 04-10-2018 09:46 AM
Dock Pre Fader Sends Color dalonso66 Avid S1, S3, Dock and Control 0 03-08-2018 12:57 PM
Fader off on Dock?? KPereira Avid S1, S3, Dock and Control 1 02-13-2017 01:22 PM
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Avid S1, S3, Dock and Control 0 10-01-2016 09:20 AM
