Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 08-29-2016, 01:04 PM
willie66 willie66 is offline
Default System 5MC Fader Modules not populating
System 5 MC (32 faders with 2 joysticks) running Eucon 3.1.3
Protools HD 11.3.1
DadMan 5.0.1.3
EconWS 3.2.1 (I think)
OSX 10.9.4
So, Just this week I've noticed that my S5MC faders are not populating with PT track or DadMan tracks. The MC is working as normal, with all tracks showing up on the touch screen.
Inside the module setup screen it shows all 4 modules connected.
I have never built a Layout for this system, the tracks just always populated the faders when an audio program is running, so I went into layouts and tried assigning tracks to the module faders with no success.
I have rebooted, the s5mc, and ProTools Mac. No Luck. Right after posting this I will do a full system power down and up, including the SonicWall, but I am not optimistic that this is a router problem.
One interesting thing is I am running Eucon out of the second Ethernet port, I don't think that is a problem though because I have mixed several shows with the network connected that way.
Like I said, this just stared a few days ago, until then all was working well.
So, if you have any suggestions, I am a willing listener.
William
KUED-TV Post Auido Editor/Mixer
Old 08-29-2016, 01:42 PM
Default Re: System 5MC Fader Modules not populating
Update;
So, rebooting the SonicWall did nothelp. Also I tried assigning HUI controllers inside ProTools=>settings=>peripherals => Midi controllers. I set them to use the Euphonix virtual Midi ports (grasping at straws) but that had no effect either. (I didn't expect the HUI rout to work because the DAD software doesn't populate the faders either.)
I'm sure I am missing something simple, or something in the MC setup that tells it to use all the fader banks, I just don't know what that simple something is.
Old 08-29-2016, 06:34 PM
EddieJones's Avatar
On the MCPro setup screen try removing all the 408(fader) modules and re adding them.
Old 09-01-2016, 02:55 PM
Thanks that was it. All tracks are populating now.
License not populating in iLok trevor.couture Licensing & Accounts 1 10-29-2015 12:33 PM
UVI Workstation not Populating jrosson03 Windows 7 10-03-2015 05:06 PM
FS: Solid State Logic SSL X-Rack system with 4*XR618 Dynamics modules Recallbeats Buy & Sell 0 11-22-2014 05:08 AM
System 5MC, modules go offline very often Electrix030 System 5 1 11-04-2012 05:38 PM
6.4 - Mackie HUI - Midi Control not populating peripherals austinacoustic Pro Tools TDM Systems (Mac) 1 11-03-2012 10:25 AM
