  #21
Old 03-06-2016, 08:55 AM
Default Re: PCIe SSD cards and Mac Pro upgrades
900 MB/s read/write on a SATA drive is impossibly fast and likely meaningless when trying to compare drives. That performance is likely measured through the filesystem cache, and might measure similarly fast numbers with slower drives.
  #22
Old 03-06-2016, 09:21 AM
lucienpalmer lucienpalmer is offline
Sorry, I mistyped. It's over 600MB/sec, not 900. I'm dyslexic (really).
To be specific, Blackmagic Disk Speed Test is giving him 686.1 MB/sec write and 689.5 MB/sec read with a Samsung EVO 1TB SSD (MZ-75E1T0B/AM) connected internally to a CalDigit FASTA-6GU3 PCI card.
Unfortunately, CalDigit discontinued the card with internal SATA, and the new model only has external SATA. I wanted a clean install with my SSD mounted internally. So instead, I bought a similar card on Ebay from Hong Kong (link below). It works great, but the internal SATA port must be running though it's USB 3.0 bus, because my internal SATA SSD appears as an external USB device to the Mac. I'm using an OWC Mercury Extreme Pro 6G SSD and I get 340 MB/sec write and 341 MB/sec read using AJA's disk red/write test.
http://www.ebay.com/itm/272059253733...%3AMEBIDX%3AIT
I just bought a Samsung EVO 1TB SSD (MZ-75E1T0B/AM). It should be here Tuesday. I'm going to run speed tests on the drive via my USB/SATA card and with my OWC Accelsior SSD card:
http://eshop.macsales.com/shop/SSD/P...sior/S-Carrier
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
MacPro 3.45 12-core, OSX 10.12.6
S6 M10 16-5, Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
Certified for Dolby Atmos Home Entertainment
  #23
Old 03-06-2016, 09:32 AM
OK that makes more sense, but the Blackmsgic tests do measure cached results, which can confuse comparisons between drives.
  #24
Old 03-19-2016, 12:50 AM
munkitkat's Avatar
munkitkat munkitkat is offline
Cheap and proven with 4,1 and 5,1 towers.
  #25
Old 03-19-2016, 01:27 AM
Buccanears's Avatar
Buccanears Buccanears is offline
Don't forget your graphics card. The GT120 has been known to be a bit slow and messes with the GUI. An ATI 5770 is a much better option.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
  #26
Old 03-19-2016, 07:54 AM
True, and this card is better than the 5770. Plus, OWC offers cash for trade-ins on your old card.
http://eshop.macsales.com/item/Sapph...o1HhoC8-zw_wcB
  #27
Old 03-19-2016, 09:13 AM
Will Russell's Avatar
Will Russell Will Russell is offline
I've got a 12 core 5,1 that I use for a ProTools HDX rig. I have a Sonnet Tempo SSD Pro Plus 6Gb/s SATA PCIe 2.0 Card for Dual SSDs and 2 480G OWC Electra 6G drives and I couldn't be happier. Overall system response is wicked fast, and although I cannot actually measure it, it is my strong impression that it does improves ProTools performance overall.
I also traded out my GT 120 for a faster ATI Radeon Hd 5770.
Regarding Pro tools and graphics performance, Yosemite is fine if you run the Quartz debug in the background. you get a little bit of video tearing but the meters are smooth and accurate. El Capitan and Pro Tools graphics are currently a mess and best avoided.
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.14.5, PT2019.6, HDX, D-Command
Retina 5k iMac OS 10.14.5, PT2019.6, MBox3
Retina MacBook Pro OS 10.14.5, PT2019.6
  #28
Old 03-19-2016, 10:22 AM
+1 on running Quartz debug to disable beam sync. I don't use extended desktop video, but disabling beam sync helps my meters run smoother.
  #29
Old 03-19-2016, 10:30 AM
To get back on topic, the latest and greatest way to go for SSD would be to avoid SATA connectors and use M.2 chips. Put four of them on the same board and install it in the x16 (slot 2) of a MacPro 2010-2012.
http://amfeltec.com/products/pci-exp...2-ssd-modules/
You can get speeds of almost 5500 MB/sec. Check out the barefeats test below.
http://barefeats.com/hard210.html
Pretty crazy.
  #30
Old 03-26-2016, 01:36 PM
K Roche's Avatar
K Roche K Roche is offline
I recently upgraded my mid 2010 Mac Pro 6 core 333 ghz with a single Samsung SM951 512GB M.2 80mm PCIe 3.0 x 4 Internal Solid State Drive MZHPV512HDGL-00000
placed it in PCIe slot 3 with the Lycom DT 120 adaptor/card and is currently my boot drive.
Amazingly simple 5 minute project. simply screw (one screw provided with DT 120) the SM 951 blade on to the DT 120 adaptor/card (can only go on one way) . Remove the side access cover of the Mac. Then hand loosen the keeper bar and slide out the available PCIe slot's blank plate from back of the Mac. Then it simply push and snap fit the DT 120 adaptor/card into the the available pcie slot (can only go in one way ) Hand tighten the keeper and put the side cover of the Mac back on. Done
So here are the Black Magic read write speeds as you can see fairly close to the "barefeats" test score ( linked by lucienpalmer above) for the single 951 configuration .
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB, Radeon Pulse RX 580 8GB GDDR5 Dual HDMI Graphics Card..... OS- Mojave 10.14.6, and PTHDN 2019.12 on on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2nd Samsung 970 EVO 1 TB -- both in dual drive Crest I/O PCIE controller adaptor card
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Accel Cards next to other PCIe Audio Cards in the same Mac Pro for PT 10+11? relaxo Pro Tools 11 11 05-13-2018 03:01 PM
HD 3 Core PCIe and 2 Accel Pcie cards JonGon Buy & Sell 0 04-05-2015 10:02 PM
Are all pcie cord cards, accel cards? fourthtunz Pro Tools TDM Systems (Mac) 2 11-20-2011 09:41 AM
PCIe cards not being recognized in my MAC PRO ProTools not launching with cards in phatbeatstudio Pro Tools TDM Systems (Mac) 6 10-16-2011 12:35 AM
Mix up PT HD PCI and PCIe cards? Matiz Pro Tools TDM Systems (Win) 0 03-01-2006 02:25 PM
