Re: Could not allocate memory for the disk cache....
Should Pro Tolls and the recordings both be on the second hard drive?
I'm also getting a slew of errors like this on a clean proper install, I'm sooooooo disappointed in this "Industry Standard" software that can't even run from scratch. I can't believe they are getting away with it.
By the way, try running PT as admin by right clicking on it, if that doesn't work re-install in as Admin (again by right clicking on the install .exe) |
I'm getting the same error on launch:
"Could not allocate memory for disk cache. Try lowering your disk buffer (DAE Buffer), disk cache size, or engine voice count. If you got this error on launch, delete your prefs and try again. (-9514)" I was using Windows 8 beta and upgraded to win 8 pro. I have protools 10.3 and the 003 and never had any problems. I thought I had 10.3 open in the new win 8 last week but possibly not. I renamed ProToolsPref.ptp in Users/app data (is that the prefs they mean?). SiSoftware Sandra ID Host Name : Homeboy Workgroup : WORKGROUP Computer Mainboard : Intel D975XBX2 Serial Number : BQB264****** BIOS : Intel BX97520J.86A.2838.2008.0903.1859 09/03/2008 Total Memory : 8GB DIMM DDR2 Processors Processor : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4C 2.4GHz, 2x 4MB L2) Socket/Slot : FC LGA (Socket T) Chipset Memory Controller : Intel 82975X Memory Controller Hub 4x 267MHz (1GHz), 2x 4GB DIMM DDR2 802MHz 128-bit Memory Module(s) Memory Module : Super Talent SUPERTALENT02 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Samsung M3 78T5663QZ3-CF7 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Super Talent SUPERTALENT02 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Super Talent SUPERTALENT02 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Monitor/Panel : ViewSonic VX2433wm (1920x1080, 29.7") Monitor/Panel : ViewSonic VX2433wm (1920x1080, 29.7") Video Adapter : NVIDIA GeForce 8500 GT (16 SM4.0 1GHz, 512MB DDR2 850MHz 64-bit, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 8500 GT (16 SM4.0 1GHz, 512MB DDR2 850MHz 64-bit, PCIe 1.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce 8500 GT (16SP 2C 1GHz, 512MB DDR2 850MHz 64-bit) Compute Shader Processor : NVIDIA GeForce 8500 GT (16SP 1GHz, 512MB DDR2 850MHz 64-bit) CUDA GP Processor : NVIDIA GeForce 8500 GT (16SP 2C 1GHz, 512MB DDR2 850MHz 128-bit) Storage Devices WDC WD1002FBYS-02A6B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (C:) WDC WD30EZRX-00MMMB0 (3TB, SATA600, 3.5") : 3TB (K:) WDC WD2001FASS-00W2B0 (2TB, SATA300, 3.5", 7200rpm) : 2TB (D:) Seagate ST33000651AS (3TB, SATA600, 3.5", 7200rpm) : 3TB (T:) WDC WD5000YS-01MPB1 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (R:) WDC WD5000YS-01MPB1 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (Z:) WDC WD5002ABYS-01B1B0 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (R:) WDC WD20EARX-00PASB0 (2TB, USB2/SATA600, 3.5") : 2TB (J:) Seagate ST31500541AS (1.5TB, USB2/SATA300, 3.5", 5900rpm) : 1TB (A:) WDC WD20EADS-00R6B0 (2TB, USB2/SATA300, 3.5", 32MB Cache) : 2TB (B:) HP Photosmart 8200 (USB1) : N/A (E:) PIONEER DVD-RW DVR-112D (ATA66, DVD+-RW, CD-RW, 64kB Cache) : N/A (F:) WD Virtual CD 1110 (700.4MB, USB2) : 668MB (H:) Logical Storage Devices System Reserved : 100MB (NTFS) 2000Blue (J:) : 2TB (NTFS) @ WDC WD20EARX-00PASB0 (2TB, USB2/SATA600, 3.5") 1500White (A:) : 1TB (NTFS) @ Seagate ST31500541AS (1.5TB, USB2/SATA300, 3.5", 5900rpm) 2000Black (B:) : 2TB (NTFS) @ WDC WD20EADS-00R6B0 (2TB, USB2/SATA300, 3.5", 32MB Cache) SYSTEM (C:) : 931GB (NTFS) @ WDC WD1002FBYS-02A6B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Removable Drive (E:) : N/A @ HP Photosmart 8200 (USB1) 2TB (D:) : 2TB (NTFS) @ WDC WD2001FASS-00W2B0 (2TB, SATA300, 3.5", 7200rpm) 3TB (T:) : 3TB (NTFS) @ Seagate ST33000651AS (3TB, SATA600, 3.5", 7200rpm) raid (R:) : 932GB (NTFS) @ 2x WDC WD5002ABYS-01B1B0 (500.1GB, RAID/SATA300, 3.5", 7200rpm, 16MB Cache) 3000Green (K:) : 3TB (NTFS) @ WDC WD30EZRX-00MMMB0 (3TB, SATA600, 3.5") ZiegsPhotos (Z:) : 466GB (NTFS) @ WDC WD5000YS-01MPB1 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Optical Drive (F:) : N/A @ PIONEER DVD-RW DVR-112D (ATA66, DVD+-RW, CD-RW, 64kB Cache) WD SmartWare (H:) : 644MB (UDF) @ WD Virtual CD 1110 (700.4MB, USB2) Peripherals LPC Hub Controller 1 : Intel 82801GH (ICH7DH) LPC Interface Controller LPC Legacy Controller 1 : SMSC LPC47M182 Audio Device : Intel 82801G (ICH7) High Definition Audio Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : Intel 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : Intel 82801GB/GR/GH (ICH7) Serial ATA Storage Controller Disk Controller : Intel 6145 SATA2 Controller USB Controller 1 : Intel 82801G (ICH7) USB Universal Host Controller USB Controller 2 : Intel 82801G (ICH7) USB Universal Host Controller USB Controller 3 : Intel 82801G (ICH7) USB Universal Host Controller USB Controller 4 : Intel 82801G (ICH7) USB Universal Host Controller USB Controller 5 : Intel 82801G (ICH7) USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : Intel TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour) Printer : DocuCom PDF Driver (2400x2400, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : HP Photosmart C3100 series (1200x1200, USB, Colour) Printer : HP Photosmart 8200 Series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : DocuCom PDF Driver (2400x2400, Colour) Printer : HP Officejet 4200 series (300x300, USB) Printer : HP Photosmart C3100 series (600x600, USB, Colour) Printer : HP Photosmart 8200 Series (600x600, USB, Colour) Scanners and Cameras Scanner : Hewlett-Packard HP Photosmart C3100 (Scanner, USB) Peripherals Media Player : WD My Book 1140 (1.82TB) Network Services Network Adapter : Intel(R) PRO/1000 PL Network Connection (Ethernet, 1Gbps) Operating System Windows System : Microsoft Windows 8 Business 6.02.9200 Platform Compliance : x64 Windows Experience Index Current System : 4.6 |
And of course Windows 8 has been touchy about this anyway. If this is your production machine I would go back to W7. Try this utility for your Prefs deletion. https://dl.dropbox.com/u/6233434/TRASHER%2010.zip
Pro Tools needs to be on the system drive, that is, the same drive as the operating system. Check out this page: Pro Tools Computer Optimization Guides – Mac and Windows
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
#16
I am having this problem too after upgrading PT10 to 10.3.3. I used my systems uninstaller and uninstalled just Pro Tools. I did not install it as an administrator but I ran it as an administartor after installing. I had issues installing Pro Tools 10 in the Program Files folder and had to install it in the Program Files (x86) folder, so that won't change anything. Everything I have is up to date. I am going to try a few other options but more input will be helpful.
#17
I just got mine to work. I opened the installer and it prompted me to first uninstall the HD driver (I dont have HD, not sure how it got installed) and then I had to restart. This didn't fix it. So then I changed the Setup.exe file to Run as Administrator, opened it and selected the Repair option. This did fix it. I am not sure if it was choosing to rapair as an administrator or just using the repair option but it worked. Lets see if this works for everyone else.
#18
1) Install Windows 7 x64 from scratch, completely new and fresh (formatting the hard drive for that purpose). 2) Completely update Windows to Service Pack 1 with all current updates from Microsoft Update. 3) Install iLok drivers from ilok.com. 4) Follow all the Windows 7 optimization tips found here: Optimizations
6) Install Pro Tools (latest version, restart whenever it's required, very important). At this point, there should be no reason (under normal circumstances) for your Pro Tools not to work. There are a lot of guys that still give you advice on doing things that are not longer required for Pro Tools (like disabling your network adapters, Windows desktop composition, etc - those are now troubleshooting steps, not requirements). Yes, you should record using a different hard drive for audio - but that doesn't mean you cannot test a light session using the system hard drive. If things are not working after all this, then start following the troubleshooting steps described in the optimization links I just gave you. If you still have trouble, then start checking for hardware issues. HTH Francisco
The audio world is full of (mainly very expensive) placebos. Windows 10 Pro 64 Bit Pro Tools Ultimate (perpetual with active updates/support plan) RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP) Monitors: Yamaha MSP7 and Yamaha HS8S Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! ) Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads) 128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each) Boot disk: Samsung 980 Pro M.2 2TB Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32'' |
#19
Guys: Windows 8 is still not supported, so stick with Windows 7, and 64 bits to get advantage for the disk cache if using HD or CPTK.
First: go through all these steps on this guide before even install ProTools... http://avid.force.com/pkb/articles/e...oting/en349411 Always, and I mean "ALWAYS", install software as "administrator", run it logged as this user the first time, check that everything runs fine, and then run it as a normal user, or an admin user if you want. Hope this help.
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
#20
BS like this is the main reason why I gave up on PT... I was sent a PT session and had no choice but to install it... And now I gotta do a whole bunch of Sandra Hoolahoop to get some help.... Everytime i have to install this PT I have isproblems.... On the other hand Reaper takes a minute to install (dl time included) and gives me zero headaches SMH
Could not allocate memory for the disk cache. Try lowering your disk buffer.. | slim_shady | Pro Tools 10 | 15 | 05-09-2017 05:20 PM |
Could not allocate memory for the disk cache. try lowering... | def3mno62 | Windows | 3 | 10-25-2013 09:11 AM |
Could not allocate memory for the disk cache problem | digital2020 | Eleven Rack | 1 | 06-10-2013 12:38 PM |
