  #111
Old 03-14-2015, 11:34 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Need a new quieter fan to HD IO..
Originally Posted by Meads View Post
They are running the same firmware, and I didn't open up the new unit to check on the fan. But it has to be a different one.
Has to be if the software is the same
Janne
  #112
Old 06-16-2015, 09:31 AM
nedd nedd is offline
Can anybody help?
the Silenx has both wires black, while original HD fan has red and black.
Which one of this two black on Silenx should replace red one?
  #113
Old 06-16-2015, 09:52 AM
JFreak's Avatar
You need to try it with your hand, forst with the original and then your first try. If it blows air to same direction you have succeeded. If you dont feel anything it needs to be reversed. Nothing breaks by trying, in only affects which way air goes (in/out)
Janne
  #114
Old 06-16-2015, 10:02 AM
thanx, did you also do it?
Funny thing is that Silenx has 3 wire (all black), I just did connect two of them and the fan is not running at all. Perhaps some of the guys who did put silenx in HD I/O can point me to which wire goes where?
  #115
Old 06-16-2015, 10:06 AM
it's ok now, just put some other combination and the fan now works and push the air outside. Very quietly!!
  #116
Old 08-28-2016, 11:04 PM
Rajsmoove Rajsmoove is offline
Just swapped my fan out with the Silenx one. Its a whisper of air now!
For those wondering, the middle wire of the silenx fan corresponds to the red wire, and the second one that also connects to the additionally supplied power adapter is the black one.
Also using a small screw driver and pushing down on the metal clasp thru the connector hole allowed me to pull it out easily without pliers. It slides right out!
Is the Avid IO fan quieter than the 192 fan? Eric Lambert Pro Tools HDX & HD Native Systems (Mac) 83 01-22-2015 07:13 AM
Are the new HD 8x8 i/o's quieter than the last gen? guitarzzan Pro Tools 9 2 06-16-2011 11:52 PM
Quieter internal drive for new mac pro? bsmith23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-26-2009 05:48 AM
G4 quieter fan exchange Seller Pro Tools TDM Systems (Mac) 0 02-21-2003 09:53 PM
Which PC's are quieter? MGruschow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-04-2000 12:25 AM
