High Buffer settings with Command 8 and Pro Tools 10
Ok, So I did some troubleshooting last night and discovered that without my Command 8 engaged in the "Peripherals" section, basically when it's turned off, I can operate Pro Tools 10 smoothly at 256MB and even down to 64MB(minor cracks/pops) buffer settings on my RME Fireface 800
However, when the Command 8 is engaged, just something simple as switching Plugin windows using a mouse prompts the low CPU usage message. This is very uncomfortable until I use 1024MB Buffer which is not a huge delay on my RME FF800 but it is noticeable nonetheless. I would love to work comfortably at 128MB to 256MB but the Command 8 is sadly stopping me from doing this. I will contact Avid and see if they can do something about this. But if anyone here experiences having to use Higher Buffer settings to work in Pro Tools 10 while the Command 8 is engaged, let me know if there is a workaround. Thanks Windows 7, i7 Quadcore, 12GB RAM, 8 processors |
Re: High Buffer settings with Command 8 and Pro Tools 10
Shot in the dark here, but I suspect a USB driver issue. You might try adding a PCI/PCIe USB card(USB2) and connecting some stuff there, instead of the current USB ports. It may also take some experimentation to find if and what works better, when moved to the card USB ports. Those cards are pretty cheap on eBay
High Buffer settings with Command 8 and Pro Tools 10 | tj2toxic | ProControl, Control|24, Command|8 | 1 | 08-08-2013 04:34 AM |
High Noise Floor on D Command / Xmon | Squint Music | ICON & C|24 | 1 | 02-19-2013 10:48 AM |
High-pass filer (HPF) settings on Mbox Pro ? | chrisdee | General Discussion | 5 | 11-22-2011 03:01 PM |
firewire glitch (not buffer or high cpu!) | badda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-19-2007 03:58 AM |
HELP...Buffer Settings Pro Tools and Reason | basscat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-27-2006 02:38 PM |
