Old 05-23-2018, 10:12 AM
KeyplayerG's Avatar
KeyplayerG KeyplayerG is offline
Default VCA Spill with Artist Series Questions
I have a couple of questions regarding the VCA Spill feature now available for the Artist Series.
1)Do you have to have the PT App to make the VCA Spill feature work on the Artist Series components?
2) Is the spill feature limited to the Mix units?
3) If you have more than 8 VCA Masters, will the balance spill into the next unit? For example: The preference settings says to assign faders 9 - 16 for VCA faders. Would the 9th VCA fader then spill to fader 17 in a 2nd Mix or MC Control?
4) Finally, if the PT App is required to work on A.S. units, is it also required for the S3, or is that function built into the S3's architecture?
Old 05-23-2018, 04:05 PM
its2loud its2loud is offline
Default Re: VCA Spill with Artist Series Questions
1)Do you have to have the PT App to make the VCA Spill feature work on the Artist Series components? yes
2) Is the spill feature limited to the Mix units? no
3) If you have more than 8 VCA Masters, will the balance spill into the next unit? For example: The preference settings says to assign faders 9 - 16 for VCA faders. Would the 9th VCA fader then spill to fader 17 in a 2nd Mix or MC Control? yes
built in
Old 05-23-2018, 05:07 PM
KeyplayerG's Avatar
Originally Posted by its2loud View Post
built in
Thanks!
VCA Spill and eucon 3.3 on artist series controllers Cryos Artist Series 3 09-25-2015 06:36 AM
Two questions for Artist Series users w/PT: reichman Post - Surround - Video 4 07-01-2015 08:21 AM
Two questions for Artist Series users w/PT: reichman Artist Series 3 06-27-2015 12:54 PM
Questions for Avid Artist Series Experts tzujan Artist Series 3 11-03-2014 07:06 AM
Artist series spill master faders or VCAs? Picture Start Artist Series 9 01-25-2014 12:59 PM
