Old 05-23-2018, 03:52 PM
DannDMann DannDMann is offline
Default What should I run my Eleven rack through?
I picked up an Eleven Rack to try one out again. After 2 weeks I have liked the sounds I am getting when I record into the ProTools that came with it. My issue is I have tried to run it straight through my PA (Admittedly it's a fairly cheap one) and also through a Line 6 Spider Valve amp and didn't like how it sounded. With the amp I tried it straight in the front, in the fx loop and also just in the fx return with varying results but not crazy about any. My question is for those who don't just run this through a computer (or front of house when playing live) what do you run your Eleven Rack through and get good results? Sorry, I know this has probably been asked before but any advice I'd appreciate. - Dann
Old 05-24-2018, 09:55 AM
Did you search for those past questions?
Its not just what to use but how you use it and for what use. What exact full range monitors are you trying? For what use? In what size room/location?
Suitable full range monitor(s) are likely best. but with cab emulation turned on and time spent playing with speaker break up settings. Full range monitors like the QSC K10 work well for many folks in smaller locations or as stage monitors.
There are lots of things to tweak. Those monitors may be pretty directional, like in a practice room/smaller venue bouncing one of two monitors off a wall might help capture the feeling of an open back cab.
Guitar amps/cabs similar to what you want to emulate can also work, usually with cab emulation turned off, and driven into the FX loop return, and some time spent gain staging and playing with relevant power amp controls if there are any.
Cab emulation is unfortunately a global setting which makes it less favorable to use a mix of guitar amp/cab and full range monitors.
Old 05-24-2018, 03:08 PM
DonaldR DonaldR is offline
Default Re: What should I run my Eleven rack through?
I'm using an EV ZLX12P top (hpf at 80hz) with an EV ZXA1 sub, rig full output: sounding fantastic for guitar and bass.
Before that I used a Peavey Classic 60/60 tube poweramp thru a Peavey 4x12" cab loaded with Celestion G12-K85, rig no cab: sounded fantastic but limited to guitar only.
I tried front of a 1x12" SS combo, and thru fx return, rig no cab: sound meh.
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! Justin1524 Eleven Rack 0 11-27-2015 02:53 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Some experimental tracks using Eleven rack and Eleven RTAS kittybite Eleven Rack 4 06-18-2013 12:18 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
