Old 03-04-2012, 06:18 PM
Rocknrails Rocknrails is offline
Default Fades not working
Fades do not work on my PT 10.0.1. on Lion 10.7.3. They are greyed out in the menu and the shortcut does not work. Fades do work on sessions that I have received from professional studios, and on the Audrye Sessions that came with PT 10. They just don't work on any sessions I have made on my own computer. The fades did work previously with PT 8 LE. Are there any settings I should be checking? What can I do?
Old 04-15-2012, 12:11 PM
jax72 jax72 is offline
Default Re: Fades not working
Something similar happens to me.
Pt 10 trial.
highlight beginning (or end) of clip, press F, nothing happens.
Annoying.
A.
Old 04-23-2012, 10:32 AM
stelomax555 stelomax555 is offline
Hi all, I also have a problem with fades. I have created a new project and when it comes to creating a new fade it is drawn as normal. However, when playing back the audio, the fade isn't working. Any ideas why this isn't working? I have already tried trashing the prefs and re-starting my computer!
Old 04-23-2012, 01:49 PM
Hmm. It works here.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 05-26-2012, 11:51 PM
Adwel Adwel is offline
Im able to create and hear fades working properly within audio tracks, but not midi or instrument.
Is that an actual limitation? VERY hard to believe...
Old 05-27-2012, 01:36 AM
rafukyo rafukyo is offline
Hitting F and nothing happens, means the edit shortcut is not activated. You have to click on thr a..z button on the right up of the edit window. or hit cmnd+f (on Mac) or cntrl+f (on PC).
Old 05-27-2012, 08:42 AM
Philthy Philthy is offline
The problem here is your lack of familiarity with MIDI! View the volume control data on the MIDI track and draw a fade if you need one. What would you have a fade on a MIDI track do? Drop the fader? Well there is already a function for that. The fade function makes no sense in the context of MIDI. You need to learn how to use automation in ProTools.
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 04-27-2018, 09:11 AM
TheGrobinson TheGrobinson is offline
I'm having this exact problem (and more) with sessions on Pro Tools 8HD. I made a new boot disk with a fresh install of pro tools and OSx 10.6.8 and the issue persists. Any Thoughts?
Fades Not Working jrtme macOS 6 08-30-2012 10:24 AM
Fades not working well on PT9 (may be I am doing something wrong?) garnoil Post - Surround - Video 11 04-24-2012 10:33 AM
fades/crossfades not working grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-11-2009 02:23 PM
Fades are not working PLEASE help mdhues 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-28-2006 08:57 PM
Auto-fades NOT working? wonderfall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-07-2003 09:23 AM
