Old 05-14-2020, 07:25 AM
ApplescriptForPT ApplescriptForPT is offline
Default ProTools won't recognize "Remote Audio" when using MRD
When I connect to my Windows Pro Tools machine using Microsoft Remote Desktop, a new sound output is created called "Remote Audio". Pro Tools won't recognize this as a Playback Engine. It still wants to use its Digidesign 003 hardware. I can hear the OS system sounds and control Pro Tools remotely but how do I HEAR Pro Tools when using MRD? I've tried several versions of Windows and PT and all have the same issue. My desired version to make work would be Windows 7 and PT 11 HD (work computer).
Old 05-15-2020, 09:03 AM
Default Re: ProTools won't recognize "Remote Audio" when using MRD
Windows setups are usually better off if they are configured so that Pro Tools does NOT share the interface(aka "audio engine") with Windows(or any other program). I would keep the 003 set as the PT hardware and look for another way to route audio to suit your needs(which I am not exactly clear on). Describe exactly what you wish to do and someone here should be able to offer a solution
Old 05-16-2020, 11:51 PM
I want to be able to work remotely. I need to be able to HEAR my remote Pro Tools computer - not just see it on the screen.
The problem I described won't allow me to route the remote Pro Tools audio through Microsoft Remote Desktop so I can hear it on my local machine. I know I can pay a lot of money to use Source Connect or something similar but shouldn't this be able to work by just using MRD?
Old 05-17-2020, 01:11 AM
Top Jimmy's Avatar
Either patch the 003 output to the onboard line in or use ASIO4ALL to send audio from PT to the remote workstation.
James Cadwallader
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
"Error 0028" + "Unable to perform elastic audio" themelissacheri Pro Tools | Intro Discussion 0 08-29-2016 02:06 PM
Import audio: "same unique identifier, ProTools must stamp" .. then plays wrong audio tenknuckles Pro Tools 12 0 07-29-2016 07:02 PM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
"unable to parse audio file" and "OSStatus Error -208" ! reichman Post - Surround - Video 2 03-22-2010 04:46 AM
