Old 03-28-2012, 11:54 AM
dtmprod dtmprod is offline
Default -9155 'too much automation' error message
Was having problems getting 'can't get audio fast enough from disk' error messages before. Since updating to 10.1.1, that seems to have disappeared. Now I'm getting this new -9155 error, anyone else having this challenge? I don't have any automation even running. Have tried different buffer sizes, doesn't seem to make a diff. Any suggestions from tech support?
Old 03-28-2012, 05:55 PM
RTFM RTFM is offline
Default Re: -9155 'too much automation' error message
Are you on HD or standard PT?
If you're on HD try increasing the number of DSP per voice.
If you're on standard - try using 'thin automation' (you can do this on HD as well).
Old 03-28-2012, 06:27 PM
JC925602 JC925602 is offline
Default
If you have a firewire interface, try changing the order to Mac->interface->hard drive. Having FireWire 800 followed by the interface can sometime be a problem.
JC
Old 03-29-2012, 07:57 AM
HD since 10.1.1 is only available for HD Guess I'll try increasing the 'thinning' option...
Old 03-29-2012, 06:47 PM
Set the 'thinning' to maximum, still getting the error messages. Has to be something else...
Old 04-06-2012, 01:42 PM
Lipmania Lipmania is offline
Having the same problems here. Anyone else?
-Lipmania
Mac Pro 3.0 gHz. Mac OS 10.6.8. Pro Tools 10HD
Old 04-13-2012, 12:28 AM
No one else? This one's getting kinda frustrating and I can't seem to figure it out.
I've tried numerous playback engine settings with no avail.
Help?
-Lipmania
Old 04-13-2012, 11:47 AM
Hoping that tech support is watching, wanted to report that I'm still getting these pesky -9155 'too much automation' errors even after updating to 10.1.2. This error message got introduced with the 10.1.1 HD update. I've set the HD buffer to higher settings as one link suggested, no luck there. Also raised the 'thinning' option to max, no luck there either. And what's even more odd is that I haven't even written any automation and these still pop up. Anybody have any luck in getting these to go away?
Old 04-13-2012, 12:16 PM
FajitaTone FajitaTone is offline
trash prefs etc? repair permissions? FSCK
Ray Trujillo
Freelance Audio Engineer
Old 04-27-2012, 08:00 AM
Note to tech support, just updated to 10.1.3 and I'm still getting these errors..
Automation is too dense (-9155) HDXSound Pro Tools HDX & HD Native Systems (Mac) 9 09-27-2013 01:02 AM
-9155 error on PT8 without any automation propower Pro Tools TDM Systems (Mac) 6 10-27-2009 07:10 AM
A Message But Not An Error Message RichrdC Pro Tools M-Powered (Win) 3 01-27-2008 06:57 PM
-9155 errors during looping Matt Chan Post - Surround - Video 2 01-04-2007 06:43 PM
error -9155 (automation data) celenski Post - Surround - Video 0 10-16-2006 12:02 PM
