Hardware buffer size
I had to replace my system drive in my ancient Windows 98SE, PT 5.1.1 setup. After reinstalling software, etc., Pro Tools starts up fine. But when I playback audio, I get either a 9129 error (decrease buffer size to reduce audio processing conflicts) or an error (forgot the number) telling me that the system has held off interrupts for too long and I need to increase buffer size. I've tried both 1024 and 512 sample settings, with the larger buffer getting the first error message and the second, the second.
Is there another setting somewhere I need to change? thanks, Bob |
Re: Hardware buffer size
We would need lots more information about your "new" system to be able to help you.
Please read the information in the General Troubleshooting post. It contains very important compatibility and configuration information, as well as information about how to post the information that we need to help you properly.
Dear spkguitar,
Thanks for your reply. I was not able to find a General Troubleshooting post for anything before PT 6.xx. If there is one, I would greatly appreciate your providing its location. Meanwhile, here's what I can tell you about the system. I am confident in compatibility as I checked this out very carefully at the time of purchase (obviously some years ago) and it's worked quite well since then, till the system drive failure. Any clue would be most appreciated. Thanks, Bob.
Man, how are you able to work with only 255 mb of RAM?
Well, Bruce, all I can tell you is the system has worked fine with that much RAM till the need system drive installation. I realize that compared to what's out there that my system is ancient and pretty low tech. It works for my purposes. I suppose with Windows 98SE and a Pentium III processor, that all works together.
I did play the ProTools test session that comes with the software, and it plays back fine, no buffer errors. That's playing back from the system drive. I tried copying a session on my data drive onto the system drive, but I still got either a 9129 or 9093 error, depending on whether I set buffer to 1024 or 512. I must be very close to success, so I'm particularly frustrated. Any help would be great. Thanks, Bob |
Bob,
I had the same problem (despite of the fact that i have a different system), and i solved it with spkgtr sugestion of disable the network connections. Just go to your Control Panel/NetworkConnections and disable all the connections wheter you are connected to the net or not. Do it and try to record. With me it worked! Good luck! |
That wasn't a criticism, just that it's below the recommended and/or practical amount of RAM for Pro Tools.
Cheers,
Getting that HARDWARE BUFFER SIZE with . . . . | Elton Hyland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-25-2007 05:26 PM |
Hardware buffer size | Lasse78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-21-2006 05:58 PM |
Hardware Buffer size | jpoprock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-01-2006 09:48 PM |
Hardware buffer size in relation to DAE buffer | sricabla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-04-2006 10:30 AM |
Hardware buffer size | Ryan H. | General Discussion | 1 | 12-11-2001 01:49 AM |
