Elastic Audio Question.....
I'm working on a song at the moment and i have successfully used EA on several tracks, however i need to use it on a couple more just to finish it off but for some reason i cant get it to work.
I go through the usual process of enabling EA using polyphonic, selecting analysis, however when i then go to quantize the track it wont let me click 'apply' therefore i cant go on to select 'warp' and move things about as you normally would. Can you only use EA on a certain number of tracks with LE? Any thoughts? |
Re: Elastic Audio Question.....
No limit other than what your cpu can handle, If you are finished with the first few tracks, you should commit them then move on to others to reduce cpu load. If the audio file is corrupted somehow, EA won't work on them either. Examine the PT task manager for info when you enable EA and while the track is offline to see if it is processed properly.
Thanks - i'll have a look.
I have 'committed' the other tracks i used EA on so i dont think CPU should be an issue. Ben |
I am a tad curious about how you EA though.. Here's what I do: Set track to TICK based Select EA type, (ie: polyphonic) In the track view menu I select WARP Adjust as needed.. When I grab a section that I want to quantize, I will first go through and manually set the first beat of every bar. That way there is very little if anything to have to readjust whenever I use quantize, (which is not too often). Also, you can change the sensitivity by clicking on the EA button. It defaults to 40ms in polyphonic.. increasing or decreasing can adjust the sensitivity accordingly. There is also a FOLLOW WAVEFORM button.. I have no idea of what this does.. I almost always leave things at default and add or remove warp markers using the ALT and START keys. All that being said.. if you have and use X-Form.. it is very slow to render and use... I would suggest setting all markers using poly then switching to x-form.. then waiting awhile for it to regenerate.. Let me know how what you do differs.. maybe we can source the issue..
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
If i try and move segments of the track without quantizing it first then it moves the entire track rather than just the piece of audio i want to move.
What I do is first listen to the part against a click.. if it's relatively close I will place a warp marker at the begining, end and any break in the section I am going to work on. This keeps it relatively in place. Then I will go through and manually adjust by bar, beat, whatever.., or I will quantize. The thing with an audio track and EA, if you place a marker at the begining and grab the next analysis marker and move it, everything AFTER that analysis marker will move too.. up to the point that you "locked" it with a warp marker.. If the performance isn't too good, that can create confusion. Locking is a good way of avoiding this.. but it consumes a bit of time.. Even when quantizing I am in the habit of locking the audio at the bar markers before I quantize.. but that's my personal preference.. I actually still cut and stretch/squeeze edit more than I use EA though. Again, a personal preference. There are a number of videos out by some of the folks here such as Kenny Gioia, and Stiff regarding editing and EA and such.. I would recommend them to anyone not comfortable with EA.
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
A handy trick you need here; hold the SHIFT key while you grab a warp marker to move(that will lock the marker on each side of the one you grab).
elastic audio question? | Raoul23 | Pro Tools 9 | 10 | 06-24-2011 03:13 PM |
Elastic Audio Question | michaiel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 11-10-2009 12:22 AM |
Question about Elastic Audio | Andres Gonzalez | Pro Tools TDM Systems (Win) | 16 | 12-18-2008 06:58 PM |
Elastic Audio Question | roscoe371 | Tips & Tricks | 8 | 12-10-2008 12:37 PM |
Elastic Audio question | myeviltwin | Pro Tools TDM Systems (Mac) | 12 | 08-27-2008 07:23 AM |
