Old 08-26-2003, 01:17 PM
jimmycrack jimmycrack is offline
Default lots of files across multiple cds or dvds
I know I've seen an app for this, but I can't find it anywhere...does anyone know of an app that will split a large number of files between multiple cd's or dvd's? I have a session that's 15gig. I'd like to burn it to a few dvd's, but rather then splitting the files manually, ya know...hey, I'm not lazy, it'd be nice if the computer did this instead of me...
Old 08-26-2003, 01:27 PM
Default Re: lots of files across multiple cds or dvds
Look into Stuffit Deluxe... where you stuff the files into split stuffed files.
If it's really a lot of files - you may consider that it'll be cheaper in studio/engineering time to simply buy a FireWire drive.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 08-26-2003, 01:46 PM
Stuffit Deluxe would probably take a long time to 'stuff' 15 gig into different segments. I was thinking some type of app that would simply split a single folder into smaller 650 meg folders, or 4gig folders...so i could then burn each of these folders to a CD or a DVD. I know there's an app out there, I've used it before, but I forget the name of it...any have any ideas?
Old 08-26-2003, 02:05 PM
Retrospect would be another option.. as long as you also send the storageset... and they have Retrospect on the other end.
Rail
Platinum Samples
Old 08-26-2003, 02:14 PM
Tweakhead Tweakhead is offline
If you have Apple's "Backup" software, which is free with a dot mac account, it automatically spans mutiple CDs or DVDs. The only drawback is that it requires internet access every time you launch it. Aside from that it works flawlessly.
Old 08-26-2003, 04:05 PM
vze24x2x vze24x2x is offline
I know of an App called "CD folder Partitioner" I think made by a French company. You set the Desired Size of the folders you want to create, Drag & Drop the Huge folder over the app and it automaticly divides it into several folders at the size (or very close to) you've pre-selected. It's a really great little program. If your burning backups to CD's it's a must have.
-bk
Old 08-26-2003, 05:33 PM
JC925602 JC925602 is offline
In Stuffit Deluxe you can specify "don't compress" so it's faster.
if you have Mac OS X you can use Disk Copy, and in the preference menu select the maximum size of a ".dmg" file; and it's a free software.
JC
Old 08-26-2003, 05:39 PM
-bk
Here's a link - looks good.
(UBB code is currently not working.. so copy the url)
Rail
Platinum Samples
Old 08-27-2003, 05:14 AM
froyo froyo is offline
Hello. Well here's another option for you guys. Buy a cheap IDE drive, it can even be a 5400 rpm drive, strictly for storage. They are very cheap nowadays. Get a 120 gig one for storage or smaller 40's, 60's, etc. Something to consider. Pricewatch has some EIDE 120 Gig drives for $87 bucks, 60 Gig for $55, 40 Gig for $47.
froyo
Old 08-27-2003, 10:55 AM
TXDigi TXDigi is offline
CD Partioner.
You can the split limit for CD's or DVD's.
An absolutley invaluable toold for CD & DVD-R backups
made by TED Utilities and OS9 only
HF
8hr bounce to multiple files idris Post - Surround - Video 12 04-23-2012 04:36 PM
Issue with lots of files. Frank Kruse Aspera DigiDelivery 0 02-06-2012 06:58 AM
SR conversion on multiple files tj_davies Pro Tools 9 10 02-15-2011 11:02 AM
6.1: Can't open session with lots of FADE Files Jburn34 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-04-2003 10:54 PM
Lots of little files blots 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-29-2002 06:32 PM
