Old 04-02-2002, 06:58 PM
carbomb carbomb is offline
Default system usage window??
hello all,
quick question,
after i complete a mix, delete all the sessions from the computer, when i check out the system usage window it says im almost using half of my pci space. how do i get this pci usage back down again????
thanks [img]images/icons/confused.gif[/img]
Old 04-02-2002, 09:54 PM
citi citi is offline
Default Re: system usage window??
I don't know if I have ever seen it at 0
CiTi
http://www.checkonet2ent.com
Old 04-03-2002, 01:12 AM
kalle74 kalle74 is offline
try popping some PCI cards out of your computer...
Old 04-03-2002, 06:37 AM
Gr0und_Zer0 Gr0und_Zer0 is offline
PCI gauge is usually at a quarter to a third of the bar. Those are normal values I guess...
Old 04-03-2002, 07:54 AM
electrobank electrobank is offline
From my understanding, halfway IS the normal. It may vary a little chipset to chipset, depending on IRQ Routing and PCI steering. I have never seen levels at zero. Also, I would like to note, that this level should not vary much. The only thing that should vary is your CPU and System Usage meters. And as always, if it doesn't effect your sessions, don't mess with it! [img]images/icons/cool.gif[/img]
electrobank
2+2=5
System Usage Window not as described dts350z Pro Tools 10 1 11-09-2011 05:07 PM
Help with System Usage Window!! Drummersound Pro Tools TDM Systems (Mac) 4 09-12-2011 08:48 AM
System Usage Window zlr77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-09-2011 09:54 AM
System Usage window. maccool Tips & Tricks 2 04-16-2005 01:37 PM
system bar in sys usage window hobo123455 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-01-2004 02:21 PM
