Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 01-29-2024, 06:44 AM
Fuzzyc Fuzzyc is offline
Default Easy Help (I Hope) with Pro Tools and RME
I need some help. I've used PT for many years with an RME interface. Everything has worked well all these years. I recently had to stop using PT due to a health issue. I'm back to needing Pro Tools again.
My issue now is that I can't get Pro Tools to record on a track. I suspect that this is something simple. Any help would be much appreciated!
Model: PC AudioLabs Rok Box i9
OS: Windows 10 64 Bit
CPU: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
Memory: 32GB
Internal Hard Drives:
500GB= Programs
1TBGB= Audio
1tbGB= Samples/Back Up
External Hard Drives: Verbatim 1TB USB Drive
RME Fireface UFX Interface/Preamps
Pro Tools 2023
Focal CMS 65 Monitors
Avantones
Last edited by Fuzzyc; 01-29-2024 at 06:53 AM. Reason: difficulty posting my message
Old 01-29-2024, 07:32 AM
Default Re: Easy Help (I Hope) with Pro Tools and RME
First thing to do is check(under the Hardware menu) that the RME is the selected Audio Engine.
Next, open the Setup>IO and hit the default button on the Input tab and Output tab.
Create a mono AUDIO track, set the input to input 1 of the RME, plug in a mic(with 48v if its a condenser mic). Put the track in record and test. Let us know what happens
If the above doesn't work, then its likely a routing issue in the RME TotalMix app. As I don't use that, maybe hit youtube for some tutorial help
Old 01-30-2024, 06:59 AM
Thanks for all the input! However, I've already tried these options. I'm leaning on it being a routing issue with the RME.
The Playback engine is OK.
Any other advice would be much appreciated. I don't recall ever having an issue like this.
I've tried everything I can think of with respect RME routing, and I've checked out several YouTube videos. No luck.
I'm hoping someone on the forum has come across this issue before.
Thanks for any help you can throw my way!
--Clint
Memory: 32GB
500GB= Programs
1TBGB= Audio
Pro Tools 2023
Avantones
Old 01-30-2024, 11:27 AM
The Weed's Avatar
The Weed The Weed is offline
I've had a UFX for several years and have conquered the basics of TotalMix.
How is your mic plugged into the RME? An outboard preamp or one of the UFX's (9, 10, 11 or 12)?
What kind of mic is it, dynamic or condenser?
What is the Input of the audio track you want to record the mic onto set to and what Output?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-30-2024, 07:05 PM
smurfyou smurfyou is offline
I also use an RME. Screenshots might help - one of Totalmix, one of your Track I/O, and one of the I/O setup window - Input tab.
~Will
Old 01-31-2024, 06:26 AM
Thanks for offering to help. I've been working on this for 3 days now. FYI - I've been using PT for about 15 years so I'm not new to PT.
I've been using RME for about the same amount of time.
Not sure how to paste a screen shot to you.
I'm confident that I'm handling the I/O correctly when recording, as well as arming the track for recording.
Thanks for offering some help!!
Memory: 32GB
500GB= Programs
1TBGB= Audio
Pro Tools 2023
Avantones
Old 01-31-2024, 06:45 AM
Regarding the mic I'm using, it's a Mojave MA200. It doesn't pull power from RME. It gets it from a box as (part of the MA200)
Memory: 32GB
500GB= Programs
1TBGB= Audio
Pro Tools 2023
Avantones
Old 01-31-2024, 07:23 AM
I assume you've successfully monitored the signal directly from Totalmix?
~Will
Old 01-31-2024, 08:20 AM
K Roche's Avatar
K Roche K Roche is offline
Well I do not use Windows or RME so just talking in general
My first question is are you using and or do you even need use Total Mix if you are running Pro Tools ?
So if you are getting mic input signal to the interface and to a Total Mix channel (if you are using it ) but not getting any input signal to the PT track you are trying to record . Then that would seem to indicate a routing issue .
Assuming you have the correct RME driver and firmware downloaded ?
First thing to try is (works on mac ). Hold down the (N) key while launching Pro tools and then reselect the RME in playback engine
If that does not work one thing you could try is trashing your PT preferences -- scroll down to the PC section and then reset your I/O
https://www.sweetwater.com/sweetcare...s-preferences/
If that does not work then you might uninstall and reinstall Pro Tools
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 01-31-2024, 06:21 PM
Well you don't need to actively "use" TotalMix, it just controls the mixer in the RME interface. So you can check if you're getting input. That's all you need it for in this case.
~Will
Pro Tools 11 for filmscoring. Any hope? houser Pro Tools 10 0 04-23-2012 03:44 AM
Recorded in Logic, hope to mix in Pro Tools Richard Conrad Pro Tools TDM Systems (Mac) 14 07-05-2006 07:46 PM
record/playback volume...(easy one I hope) daryl eakins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-20-2006 10:57 AM
this should be an easy one I hope nodrog1213 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-24-2004 07:53 AM
easy question I hope Gr00vechild 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-17-2001 10:21 PM
