Old 10-25-2023, 03:20 PM
graemetaylor graemetaylor is offline
Default Eucon command 'Close Session' not working.
Has anyone else noticed that the Eucon command for 'Close Session' seems to have stopped working? Wherever I assign it I can't seem to get it to work any more - used to be fine until very recently.
Thanks, Graeme
Old 10-25-2023, 05:31 PM
docric docric is offline
Default Re: Eucon command 'Close Session' not working.
Yep… same here.
Surprisingly, putting the key combo onto a soft key is broken as well.
Bummer.
The key combo still works from the keybd, thankfully.
-C' ya'
Rick
MacPro 7,1; 16 core OSX 13.5.2
PT 2023.9; Eucon 2023.6
Dock/S1/2x iPad
Old 10-26-2023, 01:34 PM
Try removing EuControl and MCClient from the Mac Security and Privacy Accessibility section, rebooting and then reading them. That fixed it when my keyboard shortcut commands in EuCon stopped working.
Scott Gatteño
Old 10-27-2023, 03:14 PM
Thanks for the input, Scott.
I was really hoping this would work, but no dice.
Strangely, it's only the Eucon "Close Session" command that seems to be whack.
-C' ya'
Rick
Dock/S1/2x iPad
Old 10-28-2023, 02:15 AM
Thanks indeed Scott, for your suggestion, but it hasn't worked for me either. Same as you docric, just 'Close Session' not working, everything else seems fine...
Old 10-28-2023, 06:53 AM
Originally Posted by graemetaylor View Post
...it hasn't worked for me either... just 'Close Session' not working, everything else seems fine...
Hey Graeme, are you by chance using a Dock or an S1 hard key to trigger these, or just from softkeys on a tablet?
Reason I ask is this:
I'm triggering them from the Right Edit Strip on my Dock. (using Shift layer)
Since the update I've also noted a bit of funky behavior from the Dock & am trying to narrow it down between Dock & Eucon.
It's looking more like Eucon so far.
Thanks!
Rick
-C' ya'
Rick
Dock/S1/2x iPad
Old 10-30-2023, 10:47 AM
EddieJones's Avatar
This looks like it broke in PT...will fix
Old 11-05-2023, 03:36 AM
I have set up a workaround for the lack of this Eucon command, albeit a fairly obvious fix, but it does work.
Go to the 'Add new' command in Eucon settings. Choose 'key' rather than 'Eucon' and enter 'Command-Option-W' (the regular keyboard command). You can also then rename it 'Close Session' for neatness.
Cheered me up a bit - yes, 'little things etc....'
Happy Soft Keys to you all,
Graeme
Old 11-06-2023, 01:24 PM
amj665 amj665 is offline
Graeme
Until now I haven't found a solution
Old 11-08-2023, 08:50 AM
Graeme
Hey Graeme,
I tried this initially & it did not work on my rig...
What's your setup? You on mac/Win? Thanks!
-C' ya'
Rick
Dock/S1/2x iPad
Can't close EQ plug-in windows from mix surface with Eucon 19.5 ThomasHQ Artist Series 8 05-15-2019 09:40 AM
Faders off Eucon command not working Led Artist Series 4 07-24-2016 05:39 PM
Save session, close session, open session next day...clips have moved. ptr22 Pro Tools 12 8 02-18-2016 06:34 AM
"could not complete close session command Neo assertion ???? bbrave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-30-2007 11:56 PM
PTLE 7.0 Quits on "Close Session" Command RMW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-23-2006 08:16 PM
