Old 05-10-2023, 12:38 AM
Pichak Pichak is offline
Default How do I offline bounce faster?
I'm using Pro Tools 11. The work requires that I need to bounce a 50 mins duration of audio. I usually bounce two 5.1 tracks with 1 stock EQ plugin sticking up in the chain. I don't need a quality bounce at all. It's just to phase compare the two tracks.
The problem is it is bounce at 3-4x of the realtime. How can I improve the speed?
It takes up to 15 mins currently and that's with 32 GB of memory on my Mac mini on Monterey 12.3.1
[3.2 GHz 6-Core Intel Core i7]
Consider that I don't need to bounce quality at all, could someone help me bounce faster? Thanks in advance.
Old 05-10-2023, 02:23 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Default Re: How do I offline bounce faster?
In my experience bounce speed is directly related to high CPU plug-ins. Rendering/comitting high CPU plug-ins ahead of time will speed up your bounces.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 05-10-2023, 02:25 AM
Sardi Sardi is online now
This.
If you want a faster bounce, get a more powerful machine. You can’t bounce at a lower quality and speed up workflow. It doesn’t work like that.
Old 05-10-2023, 07:59 PM
Hi all, I just figured, while I bounce two tracks, I also have many other tracks that I don't need to bounce with.
So the trick is to vertically isolate those tracks to be bounce being hit the offline bounce. Simply drag them out further into the session so they don't pile up with the rest of the unwanted clips.
This so this is like 4 times faster to be rough..
Old 05-10-2023, 08:15 PM
Yes.
If you’re not bouncing every channel in the render, make said tracks inactive and your CPU usage will go down and lead to a much quicker bounce.
Offline Bounce vs Realtime Bounce vs Recorded-in-Session - BIG differences in PT2021 andresix Pro Tools 13 11-19-2021 07:03 PM
Offline Bouncing with UAD plugins faster now? DJ Hellfire Pro Tools 12 1 06-15-2016 11:24 AM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
UAD2 Does Faster Than Realtime Offline Bounce in PT 11 upscaps Pro Tools 11 1 04-27-2013 06:00 AM
Faster Processor=Faster Bounce??? smashannon Pro Tools TDM Systems (Mac) 8 08-28-2000 10:36 PM
